I disagree...to many times I see pilots pitch for airspeed instead of altitude on stalls.
The really fun thing about this debate is that if the pilot properly uses pith for altitude and power for airspeed they wouldn't be in a stall either. In the airplane this is a semantics debate where in reality you are doing the same thing on final regardless of what camp you are in.If they followed pitch for AS/power for alt properly, in the first place, they wouldn't be in a stall.
What tgray said is 100 percent correct. What it falls back on, for me, with a private pilot, is what will kill you.
No pilot, I repeat, no pilot, will ever die (in any light piston) if you teach them pitch for airspeed and power for altitude. That is physics/math and it works every single time, without fail.
A pilot taught to pitch for altitude can easily find themselves in a stall spin accident when the engine fails. Without that engine they can pitch till they bend the yoke, and according to the book stick and rudder, some have, and they won't gain any altitude after their momentum burns off.
The goal with a private pilot is primacy and instinct, in other words safe habit patterns.
Unfortunately these big boy pilots with 50 million hours and an aircraft that operates primarily on the premise of momentum drill into newbie pilots that pitch can control altitude. It cannot. Even the big boys change airspeed when they pitch. However, momentum from said pitch gives altitude, and in a small aircraft that runs out very quickly since momentum rests on an objects mass and velocity. Both of which are much greater in a 737 than a 172, something these brainiacs fail to consider, IMO.
So again, pitch for AS/power for alt, in any small piston, will never kill a pilot. Period.
then next flight you have roll out on the runway and push the yoke full forward and see how much airspeed you get.
Again, elevator controls AOA (not airspeed OR altitude)
Roger said:and throttle controls power output (not airspeed OR altitude).
ajf005 said:Theres no set in stone law that works every time for different variables.
ajf005 said:what are you going to teach on an ILS when the student gets fast?
shdw said:The goal with a private pilot is primacy and instinct, in other words safe habit patterns.
To all: Those of you saying "beating a dead horse." Consider this: we have 100's of members a day that read these forums and do not post. If one of those readers has an engine failure in the future and remembers reading this thread, it could save their life. That alone makes this worth it to me.
Then post a good link to the great debates that have already occurred......if you feel this way.
Why? With each repeated typing I discover something new and solidify what I already know. Furthermore, each new debate brings a few new oppositions to the forefront. Each of these new oppositions teaches me something, so I find the discussion an important one.
If the physics work every time, then next flight you have roll out on the runway and push the yoke full forward and see how much airspeed you get.
Also, what are you going to teach on an ILS when the student gets fast? Pitch up and lose the GS or pull some power out to get the speed where it needs to be?
Absurd, as addressed by tgrayson.
I teach my students to use 90 knots indicated on the approach. Pitch for airspeed, power for glideslope. It works quite well. In your scenario, the student is pitched too far nose forward, and possibly has too much power. Most likely, it will require a change in pitch and power at this point.
I agree but which would you do first? If I'm on the glideslope and riding it down perfectly I'm not going to change my pitch right away without pulling power first. You will have to do both eventually but im going to adjust the power and slowly change the pitch to compensate for the loss of lift from a reduced airspeed. Is this the only way? Not at all but it makes the most sense to me.
What about in cruise if you have to slow down for spacing? Are you going to pitch up first or pull power first? Me, I pull power and compensate with pitch to hold altitude...it seems logical to me to do it that way but theres other ways to slow down too. I guess where I'm getting is do it the way you want but don't get deadset on "theres only one way, its the way my CFI taught me and any other way is wrong" mentality.
Pitch+Power=Performance they work together
