Bandit_Driver
Gold Member
I'd want an L1011. A brother needs his space.
Why not a 747 then? Have you seen this yet? A 747 hotel...
How well do the winglets work on the 727? I know that Delta tested out a pair of winglets on the 727.
Bandit Driver, anyone..
What is the sweep of the 727 wing?
The Boeing 737NG is swept at 25 degrees, for a top speed of .82, and a cruising speed of .78!
Wiki says the 727 has a top speed of .90 and a cruising speed of .81!
I guess I'm wondering if the wing of the current NG 737 was put on the 727, if it would be a better wing than current one, and still be as fast.
37 degrees...
The Mmo is mach .90 Our normal cruise speeds are usually between mach .75 and .80. High speed cruise is mach .84 to .86.
Nope the 727's wing is an engineering masterpiece. It was engineered for both highspeed flight and low speed flight to get into and out of shorter fields. The amount the wing grows and changes shapes is amazing.
When I got on the TriMotor, our routine cruise was 0.86M. We climbed at 250 until 10 and then went to 320kts. We later backed it down first to 0.80 and eventually to 0.78.
Good mentor when he retired was met by all his buddies with little 'crickets'. Ab, my mentor, used to say, "We got nothing to sell but speed so we may as well sell as much as we can." He was always up against the barber pole.
As for the wing, Boeing reportedly said they were NEVER again build so complex a wing.
On final.. "Gimme 50% wing disassembly!"![]()
Is there still any chance to fly the 72 these days? It seems that Capital and Kalitta etc have very few openings. Anyone know who Phoenix East's 'infamous' internship 727 FE/FO program grads get sent to?
Alex.
I remember looking at CAT a few years back. I would still like to do the FE at some point.
The FE position is a great way to learn the plane, but you will need to fly on the side to keep up your instrument skills. Just don't buy your job.
