FriendlySkies
How many of us check the ASOS just before the FAF, and then just after crossing the FAF????
How many of us check the ASOS just before the FAF, and then just after crossing the FAF????![]()
The real issue is when tower calls you while you are on the approach to tell you the new, lower rvr.
Yep. Click the timer at the NDB. I'd time it if I had briefed the LOC approach. If for some reason, we lost the GS, I'm out of there. I'll DR to the MAP and continue the missed approach from there as necessary. That's just me though. I know guys that brief everything down to circling minimums and how many runway stripes they're going to land down the runway.so then you would time once across the NDB in the above example? I would imagine no one really times ILS approaches I would guess if you loose the GS you just go around in the 121 world.
Bingo. Even then, I really only want to hear if it's at minimums or better. If it's less, I don't care what it is because I'm holding or going elsewhere. Inside the marker, I'm going to take a look.I only care about just before the FAF. After the FAF, I don't want to hear what it is again.![]()
During our initial instrument training we were always taught that the final approach fix on an ILS is glideslope intercept. But when I got to my last airline, they told me this is now different. Since usually at big airports you are vectored on to the ILS much higher than than where the OM and multees cross is. And they said your FAF is where it is marked on the Jepp page, at the cross.
So which is it for you other 121 guys out there.
FINAL APPROACH SEGMENT
The final approach segment for an approach with vertical
guidance or a precision approach begins where
the glide slope intercepts the minimum glide slope
intercept altitude shown on the approach chart. If ATC
authorizes a lower intercept altitude, the final
approach segment begins upon glide slope interception
at that altitude
...my mind can't process all of that at once.
I certainly never said nor intended to imply that they weren't. My mind just can't process all of that information. I keep it simple.Both are fine and dandy methods.
-mini
After re-reading I was worried that it did.I know you weren't, and it didn't come across that way at all..
:beer:s all around. You're buying!!
-mini
Checkers?All good! Am bored at work here in south AL anyway. Maybe go hit the local Checker's for a shake or something.![]()
Checkers?
Is that anything like a Steak and Shake?
-mini
AZ? In-N-Out FTW
-mini
They've got 'em in AZ. I've had the pleasure of eating at one down by CRQ (or is it SRQ...somewhere in Socal) and just down the road from VNY.In-N-Out is from California, son! I've eaten at the first one, actually.![]()
Dee-lish.
-mini
I've rented many an airplane out of CRQ, too. You take the CJ all the way out there?
