Polar742
Brings up a GREAT question!
So, on the 170/175, if you override the autothrottles, you'll get the appropriate annunciation, which is fine. But, the autothrottles will ALSO fight you (not much, but enough that you can feel/hear them). Once you remove your pressure, they will go in the other direction. So, you're slowing to 150 from 190. The autothrottles don't go quite to idle, and you override them. The speed gets down to about 155, you release the pressure. The throttles may go full power, and bump the speed to 170, and THEN go to idle to play catch-up.
I just turn them off, slow, and then re-engage them if that's the scenario . . .
It's a Sierra Nevada inspired scenario, though. YMMV.
I found a great technique not to override the throttles and not turn them off, but I forgot it.
Although, if I remember right, they also have some logic for pressurization and spool time incorporated as well.
The early loads were either fast all the time and sucked in cruise, or slow all the time which sucked for approach.
Sorry...long time ago holmes.
