Logging flight time
Let's get down to brass tacks here. It's 0.4. Yes I know that will make a difference to students, but how much of a difference will it really make? I mean how many students on a percentage basis show up for a checkride with 40.0 hours of logged total time? Maybe 0.1%?
If it was time that fit into some smaller category besides than total, such as solo or cross country or hood time, then I'd say every possible minute of it should be logged. But this will only apply to total time and dual. 99.9% of all students are going to have more than enough of both by the time they sit down with a DE.
And lets look at the bigger issue here. Did the FBO charge for the time? If an FBO charged me for the taxi time after I couldn't get airborne due to a MX issue, it would be the last dime they ever got out of me. And I would not be shy about giving the owner that choice. You can charge for the .4 it took me to determine that the plane you tried to rent me was not airworthy or you do the right thing and write that time off as a cost of doing business. But choose carefully because if you choose wrong you're going to lose a paying customer for good.
Consider rental cars as an example. On more than one occasion I've rented a car, got 10 miles down the road before I figured out there was a problem with the car and then turned around and took it back to swap with another. I have never been charge for the 10 miles in those cases. Never. It's how you do business.
Now if there was a CFI in the plane with student, I could see paying for the CFI. But charge me for the plane and it will be the last time you ever see me as a customer.
So the bottom line: Log it or don't. Either way, it will probably never make a difference either in term of being qualified for check ride and for getting a job. That 0.4 is simply never going to end up being critical.
I totally agree, that is what I said in my last post, I don't care about the .4 hours, that isn't the point of my post. The point is, I was going through my log book, and realized this discrepancy, since I cannot legally log this as "flight time", what should I do at this point. Chief Captain gave his advise, and I was just seeking advise as to whether I should just ignore it, and hope it is never caught by anyone, or neatly make one line through the record, and record that the totals will be changed on page xx (that is Chief Captains recommendation), or to just cross off the .4 in "flight time" and leave everything else, including the .4 in "Airplane SEL" in place. That is all I am wondering, I do agree, .4 means nothing, I just was seeking advise
I certainly wouldn't leave a discrepency and hope no one sees it. Chances are no one will, but I bet you somebody will see it only when it really counts...like that ups interview.
I wouldn't cross anything out. Just add the one extra line in the next line of your book adding or subtracting the error "found on date xxx."
And again going to the original question. Who cares? I don't log it. If you want to log it fine.
That is incorrect, sir. Nowhere do the FARs authorize you to log flight time simply because the engine is running. Now, you could release the brakes, roll forward a couple feet, and then sit there for an hour if you want before taking one trip around the patch if you want to and count it all as flight time :D. Typically, 'hobbs time' is what is used in the training environment, but that's not what the regs say, and if an inspector asks you how you log flight time, the answer is the Part 1 definition I quoted above.
I heard of a flight school training foreign students where they caught some students flying to a nearby airport and tying the plane to a tree and letting it run for their cross countries.
Guy, this is a very very simple issue...There are ONLY 2 choices here per the regs:
If you moved the aircraft for the purpose of going flying, WHETHER OR NOT YOU ACTUALLY FLEW, it goes in your total time column as well as all other applicable columns just like you actually flew. So, if you were single pilot in a cessna 172, it would be TT, ASEL, and PIC.
If you did a reposition taxi or maintenance run which was not for the purpose of flying flying...so it's not logged.
I'd do what chief captain recommends. Void the entire entry with a note that totals are adjusted elsewhere.
What did they do in the meantime? Watch? You say you want to fly airplanes. You are paying to fly an airplane. But you would rather tie it to a tree? Parents must be footing the bill and pushing the career at the same time.
I do like the image of Cessnas at the horse tie-up, though. Maybe I'll commission a faux Western piece of wall art to hang in my parlor.
What about Osprey Pilots? Do they have to log different times when the are going vertical vs. going horizontal?
An Osprey is a category of it's own.... "powered lift."
You don't change category and class during a flight. There is no reason you ever would. Keep. it. simple.
Ahhh I'd love to see the logbooks of the USAir 1549 guys.... how much glider time do you think they got? How about amphib? Does it end when they get on the raft or onto land?
Of course, you also have those guys that landed their glider in the Azores, and the Gimli glider....
I had a flight in the CRJ where the flaps failed, so i couldn't log it as complex. ;)
I heard that too, like 12 years ago. So truth or urban legend, I don't know, but sounds like a huge waste of everyone's time and money.
If you had the intention of going flying, go ahead an log that time!
(1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing
In the following scenario, when does the flight time legally end, and how much flight time can the pilot log?
1. Pilot taxis to the run-up area with the intention of flight to find the vacuum pump died on an IFR day.
2. Pilot taxi's back to the FBO. (.4 on hobbs)
3. 3 days later the pilot does a maint flight and logs the landing.
A landing assumes a take-off occurred in the definition and you can not log flight time unless the wheels leave the ground and then land on the ground later.
Lets not forget the value of what is learned by aborting a takeoff?
Consider your nearing Vr in a twin and you fell a strong vibration and the planes looses directional control. You abort and come to a stop on the runway, followed by a precautionary shutdown on the taxiway, firetrucks, tugs all sorts of excitement ensue.
On this flight the pilot didn't actually 'fly' but he learned a whole heck of a lot!
