Logging flight time
(From Part 1)
Flight time means:
(1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or
(empasis added)
i wish we logged it that way.....
What's wrong with "because I want to" ? The FAA doesn't specify this particular category of flight time, so he can put whatever he wants to there.
Very true. Your logbook is yours, so you can log whatever you please. Just be sure to exclude the "looking at pretty singles" time when showing compliance with any requirement for the issuance or exercise of the privileges of any certificate, rating, or authorization under part 61. Otherwise, you may find yourself in violation of §61.59(a)(2).
I was told that any time the engine was running, I could log it as flight time. I've had an alternator failure on the ground (which equaled out to .2 on the Hobbs) and my instructor said to go ahead and log it as TT and ASEL.
Is that incorrect? :confused:
If you had the purpose and intension of actually going flying, then log it. When you say I log all the flight time when the engine is running? What about maintenance runups? Otherwise a bunch of A&Ps could have a logbook full of flight time;)
Yea, me too. We kind of get screwed, don't we? Sometime we spend 30 minutes on the taxiway troubleshooting one problem or another, and none of it is loggable for us; this amounts to several hundred hours of lost flight time in my book. Why do we have to be different in the AF? That's the million-dollar question. Rest assured we're held just as accountable on the ground as for any other phase of flight, and in the C-5, many times ground ops is way more hazardous. It definitely takes more brain cells than sitting in cruise flight for 8 hours.
That is incorrect, sir. Nowhere do the FARs authorize you to log flight time simply because the engine is running. Now, you could release the brakes, roll forward a couple feet, and then sit there for an hour if you want before taking one trip around the patch if you want to and count it all as flight time :D. Typically, 'hobbs time' is what is used in the training environment, but that's not what the regs say, and if an inspector asks you how you log flight time, the answer is the Part 1 definition I quoted above.
I recall hearing somewhere that most airlines allow military guys to add a fixed time increment to each flight. Is that not true?
How is your flight time logged? Is it wheels up to wheels down? Which military branch are you in?
Granted, my T-1 experience hasn't accounted for that much but I'd say probably 10 hours easy in UPT that i haven't been able to log because of it...We get our drop in about 3 weeks.....fingers crossed for a C-5, C-21 to Ramstein/Peterson, or C-17 Elmendorf.....in it
I cant speak for operational but in UPT it's wheels up to touchdown....and sometimes we add 5 minutes for taxi time (depending on if it requires a 4293 or not)
Yes, it's takeoff time to landing time; USAF. Yes, some airlines provide for one conversion formula or another. Sometmes it's a pain in the rear to present your times the way each carrier wants to see it, but that's what you have to do.
Good luck. If you go C-5s, I'll probably see you around at Kelly.
That depends. Certain certificates and ratings may require the totaling of, for example, multi time, and your entry of non flight time in that "convenience" column could be viewed as a falsification of flight time.
I'll stand by my own saw, if you're going lo log the time you spent in seat 21B, make it clear in some way that it doesn't count.
My students fly under JCAB rules and they only log takeoff to landing. I add 15 minutes to each flight in my logbook because with all our procedures and taxi time (which is very accurate). At first I didn't really put much concern into this extra time until I started figuring that I could easily conduct over 200 flights in a year and that equals to over 50 hours of loggable time I was missing out on.
(From Part 1)
Flight time means:
(empasis added)
Jshutt,
I wouldn't log it. You moved under your own power, but how long did it take you to come to rest after landing? That second part is equally important because of the AND logic.
I completely agree Chief Captain. Just because the aircraft start the move under its own power for the purpose of flight doesn't mean I can log it as flight time, because when did the aircraft come to rest after landing? It is basic logic that for a statement to be true, the ENTIRE statement must be true, and the entire statement, when you do not actually have a landing, cannot be true, therefore you cannot have flight time.
My question just came about because I was looking back on my logbook and saw this "flight", or lack thereof, and it made me wonder, since I did not actually have any "flight time" could I have "Airplane SEL" time, since that is not actually under the "flight time" column. The .4 in the logbook means absolutely nothing to me, but in reality it is not logged correctly looking back on it now, and was wondering if I should just leave it alone, or cross off the entire thing, or what?
I'd neatly put a single line through it, and make the correction on the latest page with totals. I'd also make a note on both pages.
"corrected on page yy"
"correction from page xx"
I personally have always logged takeoff to touchdown, with no taxi time figured in. I might have lost some time over the years for logging that way, but that's what works and is the most accurate representation for me.
Yea, me too. We kind of get screwed, don't we? Sometime we spend 30 minutes on the taxiway troubleshooting one problem or another, and none of it is loggable for us; this amounts to several hundred hours of lost flight time in my book. Why do we have to be different in the AF? That's the million-dollar question. Rest assured we're held just as accountable on the ground as for any other phase of flight, and in the C-5, many times ground ops is way more hazardous. It definitely takes more brain cells than sitting in cruise flight for 8 hours..
So, then why don't you?
There's no reason you can't keep a logbook of your own in which you log the time according to the FAA rules. I know several fighter dudes who do exactly that. Mostly guys who are planning on getting out after their initial hitch and want to make sure they have enough hours to get their ATPs.
The problem you'll run into is when applying at a Major someday is that your AFORMS time won't match your logbook time (not that big of a deal, but you'll have to explain it none the less), and you won't be able to take advantage of any of the "multipliers" that those Majors will apply to your hours to compensate for those differences in logging.
I personally don't understand how anyone gets 'screwed' under the USAF's system of takeoff-to-touchdown+5. Over the course of a career that's 100 or 200 hours. What do you need those extra hours for, anyway? Either meeting the mins for a rating, or being competitive at an interview. Neither of those are going to be areas where a military guy's success rests on a couple hundred hours missed over the course of a decade.
