Logging flight time
clestudentpilot
Question for all of you...I know we discussed this about a year ago, but I can't find it doing a search. If you have a planned flight with an aborted takeoff, and you never fly, by the definition in FAR 1 of Flight Time, you have no flight time, since there were no landings. I know some will argue that point, but basic logic says, when reading the definition, that if you don't have a landing, you don't have flight time, since flight time ends, by definition after a landing.
My questions is, can I have an entry in my log book that says "0" under "Flight Time", but ".4" under "Airplane SEL"? The reason it was .4 is we had 2 aborted takeoffs, and tried to figure out what was wrong.
Thanks in advance.
Oh, and I will add a :popcorn:right now for my first paragraph, because I know a lot of people will argue over it
(From Part 1)
Flight time means:
(1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or
(empasis added)
(From Part 1)
Flight time means:
(empasis added)
So if he gets 3 more aborted takeoffs, he'll have an even 1.0.
Were you charged for the HOBB time you put on the plane. That is my justification to log it. If you get charged for flight time then you log the formentioned flight time.
:sarcasm:
Honestly, yes you can log it, but whether you actually log it is your choice.
This comes up ever so often, and many of us have been through a similar situation where you get up to the runway, but never take off. Can you log it? Well that depends on who you ask.
Would I log it? No. The TT and ASEL columns will always have a slight difference after you log it, and that may bring some unwanted attention to your logbook until you do your multi checkride. More importantly, showing that you spent another 24 minutes on the ground in a 172 really won't help you anywhere in life. However, had you been in a multi...:D
As an aside, this thread raises an interesting question. Why do logbooks have a "flight time" column, and another column for ASEL/AMEL etc. Under what circumstances can you change category and class during flight?
You may want to know what parts of your TT is ASEL, AMEL, Rotorcraft-Helo, etc. What do you mean by "changing inflight"?
Probably the same reason some have Glider, SES, MES, RW, etc. columns.
Not everything is a single or multi-engine land airplane.
-mini
I was told that any time the engine was running, I could log it as flight time. I've had an alternator failure on the ground (which equaled out to .2 on the Hobbs) and my instructor said to go ahead and log it as TT and ASEL.
Is that incorrect? :confused:
see below....Bernoulli Fan's answer is a bit more thorough than mine was, and since we posted at the same time, I'll give the credit to him!
The first thing people want to know usually is your TT, so that column makes it easy to add it up. I see what you're saying though. All you'd really need is a box at the bottom of each page where you could put the total of all your SEL/MEL/glider/etc. time for that page.
*edit*
Dangit MikeD.
You don't have to use a Hobbs meter. You watch will do just fine too. Consider the case where the maintenance engineer asks you to do an engine run, or when you un-tie the plane and taxi to another parking spot. You had no intention of flight, nor did you take off or land. I disagree with your instructor.
*edit*
Dangit MikeD.
I was going to elaborate on my question when I came to that realization- it's just for convenience. Not the most useful thing for ASEL/AMEL guys, but if you do that plus fly balloons, gliders and airships, it may be useful.
Never mind me, like I said, my mind is stuck at idle tonight.
But in the case I mentioned above, I did have the intention to fly...mx just prevented it. In your opinion does that qualify as loggable TT?
Jshutt,
I wouldn't log it. You moved under your own power, but how long did it take you to come to rest after landing? That second part is equally important because of the AND logic.
I can't think of a single legit reason you would have different numbers in a single entry for the aircraft category and class and Flight Time coumns.
With the exception of time you record for a simulator or a flight training device, all of the columns in your log book are "Flight Time" entries.
The ASEL column is a "flight time in an ASEL" not "time looking at pretty single engine airplanes".
If we assume (as this part of your question does) that you have 0 flight time, you have nothing to put in any column (unless, of course, you do kepp a column for "looking at pretty single engine airplanes."
I can't think of a single legit reason you would have different numbers in a single entry for the aircraft category and class and Flight Time columns.
What's wrong with "because I want to" ? The FAA doesn't specify this particular category of flight time, so he can put whatever he wants to there.
