I'm curious if anyone knows if AAL went for the carbon brake upgrade kit for their 737s?
If all else fails blame Southwest, seriously. Follow this.
The stretch NG 737s are certainly an interesting beast when it comes to landing performance. With the stretch they have to to land flatter to not hit the tail, which meas landing faster, toss on the weight of an airplane that seats 160 for the gear/brakes designed for a plane that seats 100, means less braking performance. The -900s are even worse. When EWR gets string winds from the west, the -900 can't land in EWR (everything else can even 777s). 29 is too short, and its above max X-wing for 4/22.
Its really amazing what Southwest was able to convince Boeing to do as far as under designing the current generation of 737s. In what really should have been a clean sheet design Southwest but Boeings balls in vice to make the NG basically a -300/400 with a new wing and slightly more efficient engines. Same gear, same systems, same structure, etc. Its really a shame that Southwest forced Boeing to only make a plane that only marginally matched the Airbus line and not surpass it as the NG was almost 10 years behind the 320 in development.
In other news that day Ryanair also had a -800 go off the end of the runway the same day over in the UK, although that was not nearly as dramatic (and not a hull loss). A trend of what may be to come?
That road sure did a number on the airplane. First the dropoff that you can see in that last pic and the incline on the other side that you can see on the pics looking from the back of the plane. I'm nut sure what would have been better as far as injuries go, the case that we have here with a sudden deceleration from hitting the road and the plane breaking up or a smooth runout area where the plane went into the water in one piece. Obviously if the lane went into the water after breaking up (if the plane in this case went another 150 feet) thing could have been MUCH worse from drowning etc.
