jhugz
Guppy gear swinger
I have just recently been reading through the COPA magazine, Yeah...Yeah... I know many of you feel as this is propaganda but I feel that they do a great job of compiling statistics. I feel as if this board has an unwarranted hatred of the aircraft especially from people who have never flown it. I'm nowhere near an expert but I'm getting up to about 100 hrs in the aircraft and along w/ my personal experience and some statistics I wouldn't mind talking about it.
CAPS System
Since 1999 there has been 20 CAPS activations of which 17 were saves with a total of 35 survivors. The list is as follows:
CAPS pull #1, Oct 2002, Lewisville, TX, 1 uninjured
Factors: VFR departure after maintenance, aileron unhinged due maintenance error Activation: low altitude, 1,500 feet VFR after maneuvering, first parachute deployment by pilot in a certified production airplane Landing: bushes near golf course
CAPS pull #2, April 2004, Lethbridge, AB, Canada, 4 uninjured
Factors: VFR night cruise, loss of control, possible autopilot-induced stall, night VFR over mountains, SR20 performance Activation: high altitude, deployment upon loss of control Landing: landed in scree in mountaneous terrain, skidded backwards 1/4-mile, helicopter extraction via parachute risers
CAPS pull #3, April 2004, Fort Lauderdale, FL, 1 uninjured
Factors: confusing instrument behavior, low IMC, departure climb, water in static system Activation: low altitude, 700 feet IMC, prior to disorientation Landing: landed in trees
CAPS pull #4, Sept 2004, Peters, CA, 2 uninjured
Factors: VFR climb, autopilot-induced stall, rolled inverted, attempted recovery Activation: high altitude, activated CAPS in VMC before entering IMC above 10,000 feet Landing: landed in walnut grove
CAPS pull #5, Feb 2005, Norden, CA, 1 fatality
Factors: IMC, pilot reported icing at 16,000 over Sierras, high speed descent well above Vne of 204 knots Activation: uncertain if intentional activation or due to airframe stress in high speed descent, CAPS failed as parachute found separated from airframe, located along track to crash site Landing: high speed impact in mountainous area
CAPS pull #6, June 2005, Haverstraw, NY, 1 serious injury (compression fracture of vertabrae)
Factors: IFR on approach to KHPN, pilot incapacitated from brain seizure, loss of conciousness, awoke and recovered from Vne dive, determined numbness and loss of function in legs Activation: low altitude, last radar report at 1,600 feet and 190 knots (well above Vpd of 133 knots) Landing: water, bay of Hudson River
CAPS pull #7, Jan 2006, Childersburg, AL, 3 uninjured
Factors: IMC, severe icing, loss of control Activation: high altitude, icing report at 9,000 feet IMC Landing: flat terrain
CAPS pull #8, Feb 2006, Wagner, SD, 2 uninjured
Factors: IMC, shortly after takeoff, pilot disorientation Activation: low altitude Landing: flat terrain
CAPS pull #9, Aug 2006, Indianapolis, IN, 1 fatality, 3 serious injuries (spinal surgery)
Factors: IMC, pilot incapacitation, 2.5 miles from departure airport Activation: low altitude, possibly first activation of CAPS by non-pilot, possibly not fully deployed Landing: water, pond among residential housing
CAPS pull #10, Sept 2006, Bull Bay, Jamaica, 4 uninjured
Factors: VMC cruise, passenger activated when fuel streaming from tank filler openings Activation: low altitude Landing: trees
CAPS pull #11, Feb 2007, Sydney, Australia, 2 injuries
Factors: VMC cruise, engine problems, rocket took unusual trajectory, parachute failed to open, successful emergency off-airport landing Activation: low altitude Landing: trees
CAPS pull #12, Apr 2007, Luna, NM, 1 injured
Factors: IMC cruise, climb to avoid weather, confusing instruments, terrain waring in IMC Activation: low altitude, IMC Landing: trees, mountainous terrain
CAPS pull #13, Aug 2007, Nantucket, MA, 2 injured
Factors: VFR in IMC during approach, parachute tangled with tower wires, 1 serious injury, 1 minor injury, 1 unborn child saved Activation: low altitude, IMC Landing: tower, flat open terrain
CAPS pull #14, Oct 2008, Spain, 3 uninjured
Factors: IFR in IMC during approach, pilot reported turbulence and loss of control, parachute tangled with power line wires, Activation: low altitude, IMC Landing: power line
CAPS pull #15, Nov 2008, Turriaco, Italy, 1 seriously injured, 3 uninjured Factors: fuel exhaustion and loss of engine power, parachute deployed at low altitude and late in the power-off glide scenario, approximately 400 feet above ground; Activation: low altitude, VMC; Landing: trees and grass
CAPS pull #16, Dec 2008, Gouvy, Belgium, 1 minor injured
Factors: icing, pilot attempted several outs but was unable to maintain altitude, Activation: low altitude, IMC Landing: trees
CAPS pull #17, Dec 2008, Patterson, LA, 1 uninjured
Factors: pilot reported mechanical difficulties late at night over coastal marshes, Activation: high altitude, VMC, night Landing: canal (water)
CAPS pull #18, Feb 2009, Deltona, FL, 2 fatal
Factors: instructional flight practicing low-speed maneuvers, witnesses report spinning aircraft with CAPS activation about 200 feet above ground; Activation: low altitude, VMC Landing: trees
CAPS pull #19, Mar 2009, Gaithersburg, MC, 1 uninjured
Factors: door popped open upon takeoff, pilot reported rain in the cockpit and attempted to manage door but became disoriented, Activation: low altitude, IMC Landing: residential street
CAPS pull #20, Jun 2009, Mount Airy, NC, 1 uninjured
Factors: catastrophic engine failure with oil obscuring windscreen, Activation: high altitude, 6,000 feet, VMC Landing: level field
As you can see if you actual read these statistics that if used properly the chute saves lives. Two out of the three fatalities were due to low chute pulls and the other due to a chute pull past the max chute speed. #11 was the only exception to the statistics where the CAPS system failed and was AD'ed.
Some facts about CAPs & the aircraft:
-Cirrus aircraft will float for at least a while.
-Time under canopy will be about 35 secs per 1k feet lost.
-Back injuries occurred in two of the three water landings.
-Descent under canopy is 1,700 fpm or about 20 knots. (Compared to 60 on a full stall landing) (3 times greater velocity / 9 times greater energy)
Pilot Training
They also talk about pilot training contributing a major role in Cirri accidents. A total of 55 accidents have taken place and out of these, 36 have been due to pilot factors, 1 mechanical, and 18 TBD. Yes I'm sure some of these facts are a little bias however it does bring up an excellent point. I see it everyday where people with more money then brains want to do ridiculous things w/ these airplanes. Flight into minimum weather conditions which could not be completed by this pilot w/out the use of AP, relying on the chute for situations they wouldn't feel comfortable w/ in other airplanes, and relying way to much on the bells and whistles and forgetting their roots. It's really amazing how pilots can get so far behind an airplane that doesn't have retractable landing gear, cowl flaps, and a prop lever. It is partially Cirrus' fault because they market the airplane as an easy airplane to fly with not a lot going on. However you are dropping someone into an airplane that is turbocharged, can go up into the flight levels, you now have to deal w/ 02, it can fly in known ice and is just a speed machine compared to the Cessna they probably flew before this.
Observations
1.) Cirrus needs to train better on more advance systems that pilots haven't seen before. FIKI & non-FIKI TKS systems, 02, High Alt Ops (TC), and severe weather decision making.
2.) There needs to be a better level a standardization from the top down. From my understanding you can go to MINy and do your actual CSIP and depending on what instructor you get it can be a night/day difference on how they want you to teach in the aircraft. Different ways to run checklists, procedures, etc etc etc.
3.) ADM, ADM, ADM, ADM, and some more ADM. This is the absolute, 100% most important training piece in flying this airplane. I like to ask students would you do this flight in a ratty old 172? If the answer is no then they shouldn't be doing it in a Cirrus either.
4.) Drop the Read & Do Checklists and Start Doing then Verifying. Use flows and get ahead of the airplane. Simple.
I may add more onto this thread later but for now I'm off to finish some HW. Hope this thread helped clear the air for some of you.
Source: COPA's Cirrus Pilot Magazine Volume 4 Number 6
CAPS System
Pilot Training
Observations
