Anybody have the RPM/airspeeds for a Cessna 172 & 152 for downwind, base, and final?
For both aircraft on a standard landing I use carb heat about 1000' before numbers 1500 RPM at the numbers, flaps 10 and 80 knots at this point.
Turn base power still 1500 now pitch for 70 and flaps 20.
Final is pitch for 60 and flaps 30 or if it is an older aircraft 40 if you are high and need to get down.
for a 172M I was taught:
100 on downwind/2000RPM, abeam the #s 90/1500RPM and 1 notch flaps, base 80kts and another notch flaps, final 70 and another notch flaps (30 degrees total)
Sounds like everyone pretty much does whatever they want![]()
Yep! I come in 10kts faster than everybody listed here (75kts), slowing on VERY short final to 65kts, I hate going slow.. And I land 172's with only 20 degrees. Granted I am landing on a 7000ft runway
You will burst into flames and die. It's almost as bad as running oversquare!No, haha, I just hold it down for like 3 seconds.You have notches on your flap control device (what is that thing called?)? On our 172M you just hold it down until you get the desired flap degree. Not a set-and forget thing, you have to hold it down until it gets to 20 degreees, etc.
