I don't think the prez. got the nature of my last post?
Probably not, and just for the record...I WAS THERE FIRST YOU FOLLOWED ME! lol
For what it's worth, the Emergency Procedures of the Seneca manual says "Do not extend landing gear until certain of making field. Do not lower wing flaps until certain of making field."
Depends.All good points, but in my book it's still a better 3rd option (after runway and taxiway) than a SE go-around.
Depends.
You should know prior to departing whether or not you'll have single engine climb (look at the charts in the AFM) and what it will be. That said, since you know ahead of time...maybe a SE Go-around is a better option. What's the terrain like? What's the weather like? How about an alternate?
Then there's questions like: Why are you doing a single engine approach to weather that low that you'd miss anyway? If I had to choose between flying 45 minutes on one engine to a 9000' runway in VFR weather with an ILS or landing at the field I'm right over with a 3500' runway, an NDB approach and 600-1 1/2 weather...I'm going to the long runway with good weather and the ILS every time. Doesn't matter if I'm in a light piston twin, a King air or the Citation. I'll stack the deck in my favor (getting in the first time) every chance I get.
-mini
It was probably the biggest non-event you could imagine.
Next to watching grass grow?
It's called hyperbole, stick with me here.![]()
In my Seneca, I always considered GS intercept as "making the field" with a SE, so that's where I extended flaps and gear. One way or another, I was going to land at the end of the approach; either on the runway, side step to the taxiway, or on the grass; but I wasn't going to make a go-around on a real SE. (This is provided I would break out, and in a real SE approach I'd do my best t go somewhere where breaking out wouldn't be in question.) After a lot of thought I decided that crashing in the grass under control was a much more survivable situation than attempting a go-around, which would almost certainly be fatal if I dorked it up. Besides, that's why I had insurance. I've read too many NTSB reports of pilots killing themselves by trying to save from paying the deductible on their insurance policy. I'd rather pay the deductible than have my estate do it.
Depends.
-mini
So there's a difference? Either way, the runway is now unusable, right? Whether it's because you can't see it or because there's something else on it...you probably aren't landing there.I think maybe you missed my first post. I'm not talking about making a go-around because I didn't break out, but because the runway became fouled after I started the approach.
Not necessarily. I'd rather run into the trees and rip the wings off or skid through the grass at 80 knots than flip over and crash on my back at 110 knots. Gear, flaps and wings can slow you down quite rapidly while absorbing a lot of the impact. Of course, that is unless...If you would rather crash in the grass than do a single engine go around you need to get out of flying twins.
That's the key.If it will climb enough to miss obstacles...
That's the key.
-mini
Go to a field with a nice long runway at the end of an ILS with good weather and preferably good services. It's amazing how firetrucks will keep deer away.
-mini
If you would rather crash in the grass than do a single engine go around you need to get out of flying twins. If it will climb enough to miss obstacles, you should have no problem doing it. If you do have a problem, go get some practice.
