I'm just asReally? You guys brief the ODP off of the back of the 10-9 chart for the runway you are shooting the approach to?
-mini
I'm just as...I didn't know anyone that did that. Hell, we barely look at the 10-9 long enough to take a guess at which way to turn for the FBO after seeing if we have enough room to land.
-mini
Agreed on everything.I will be the last guy to critique another outfits procedures, but it just seems like way too much information with too much possibility for conflicting information (ie, the missed is a climbing left turn to 3200 feet, the ODP is a straight ahead climb to 4000 feet, etc).
These hypothetical WWYD situations are just to get you thinking, not meant to be some catalyst that drastically changes SOPs.
Whoops. You just tossed a motor on the miss below/beyond the MAP at ASE.
Have fun with that.
-mini
Which is why blanket statements like......you could play hypotheticals all day long.
can kill ya.A transport aircraft is going to climb better than the lowest common denominator the TERPS were designed for.
...enough to make the climb gradients beyond/below the MAP/MDA?I'd rather safely take it around the patch again than be guaranteed to have an accident by hitting a deer at 120mph. Even with the flaps and gear STUCK down the plane will climb.
No, what I'm hung up on is your blanket statement that you would "go missed", period.No I edited that actually since I don't have performance info on it and can't be 100% sure. I dunno, you seem to be really getting into semantics on the premise of having multiple, serious, and unrelated system failures at a very bad time. By your logic you should never go around since IFR, VFR, etc... you'll be in a world of hurt if your flaps, gear, and engine all fail. Or never even fly at all since the fuel could be contaminated.
Ding ding ding. Winner winner chicken dinner!just another thing to think about.
can kill.A transport aircraft is going to climb better than the lowest common denominator the TERPS were designed for.
Blanket statements can certainly get someone killed. Especially if you just go around saying "hey I'm in a transport category airplane, I can outclimb terps" (period). That kind of thinking, blanket statements, thinking in absolutes...can kill. It isn't that simple.
-mini
Well you certainly have it all figured out. Excellent.That is not an opinion that can 'kill', that is simply a fact.
Actually if you'll re-read, some of those climb gradients are higher than the requirements for landing climb (which is all engines operating). I dug those up since you were getting hung up on my bringing up the engine failure at ASE.Good info. Thanks for doing the legwork. I never said you will beat the terps criteria OEI, although you and I both know most times even OEI you still will beat 200f/nm. I still think your argument is along the lines of not wearing a car seatbelt because there's a chance you could be thrown clear of the accident and avoid injury. You're advocating hitting the deer on the chance you'll have an engine fail as soon as you add power to avoid it.
