DC-9 Guys
Slightly OT, but what is the big deal about not having a GS readout? It takes 36 seconds to get a good approximation with DME.......nobody like simple math anymore? :p
Long jet.... itty bitty wing! Min clean speed to get the last of the slats retracted can be above 260 knots at heavy weights in the MD-90.
All DC-9's at NWA are CAT II certified.
Well, more weight needs a wing designed to produce a sufficient amount of lift.
Oftentimes, flying the MD-90, we'd have to fly pretty fast in order to maintain a safe margin for maneuvering. Trucking along at 260 knots, clean, below 10,000 feet wasn't all that uncommon.
When you're departing behind some jets that climb at 210 to 230 knots, it wreaked havoc on us because we had to convince SLC that it's probably better to get a vector around that traffic rather than expect us to slow to 220 knots, start throwing out flaps and wrecking fuel consumption.
McD-D more or less stretched the tube and put more power on DC-9 variants.
...I wonder if it's the same for the CRJ-900/1000. Those also have a loooooong fuselage and short stubby looking wings.
:confused:
Looks like the 900 still cleans up around 190 or 200 knots.
We have higher min clean speeds in the 757 than that (usually around 210-225).
Pretty accurate! In the 700/900 when clean up at Vt-15. Last time I flew the 900 Vt was 204 so 189 clean up speed. I'm flying one fully loaded to MKE today I'll see what the Vt is but I think it'll be around the same.
Can I just say, it's refreshing to read a thread in this section that's actually about flying, not duty times, bases, ground crews, management and whatever else you airline guys usually argue about. :)
The -9 sounds like a hoot.
