DPApilot
GUYSH! GUYSH! GUYSH!
Woware you just looking around finding things to love?
you fail at life
I love scotch. Scotchy, scotch, scotch. Here it goes down, down into my belly...
But can it be done as a student?Ok,
300nm total, you must get at least 250nm from home, with 3 "points," must be solo, and according to the three CFIs and one DPE that I asked, it can be an overnight experience.
Wow
you fail at life
Ok,
Do you have to use rudders![]()
I think you've misread a lot of this
For the bold, I don't believe he is. And according to what TGrayson pulled up, he wouldnt be able to as a Student.
Well I disagree with him. 61.127B - Find x-c in there. I don't see in my FAR where I can't let student do that. It says what we can't do, not what we can.
61 is not a course.
He only made two stops, that right there goes against this
Who cares what day he did this on. If he left at 11 pm and came back at 2 am, could he not log it? Date is really trivial in my opinion. He went on a x-c trip, in fact a student pilot away from base needing to assess changing weather. Great experience, and a great x-c.
Do you see anywhere in there that saying anything about one leg. Look at other certificate requirements, when they want that, they will say it.one of which is a
straight-line distance of at least 250 nautical miles from the original
departure point.
Just because I don't hold a CFI rating doesn't mean i'm out of my "element."
No, just giving you a hard time. You are well informed and ahead of many in your shoes.
Is a Travel John required too?PB&J's are required for this x-c....61.1..something or other I think it is.
Does that mean that you think that if you were to do a training x-c flight and stop for a hamburger you would not get to count the earlier route of flight because you shut down?see, i was always taught that if you shut down, it's a new flight
if i do all my training in n123xx with a cfi, whos to say it's not all one flight then?
Completely agree with the above. Date is irrelevant/ambiguous in this situation. There is no requirement in the FAR's stating that if a trip spans a multi day period that the days must be recorded separately. I also don't see a problem with counting this cross country as your CSEL X-C (other than the old 61 FAQ's that tgrayson so wisely brought up). Thus the question becomes: would the FAA raise a fit about using this cross country for your comm as well and is there anything to show if the 61 FAQ is still binding/valid (legally)?
Talking about commercial, not instrument. Instrument has to be done on IFR plan.
Yes, I know. My point was it would still be good for the 50 hrs of PIC x/c required for the instrument rating.
