What's the typical procedure for obtaining your ground instructor certificate after passing the written exams? Do you normally have to go to the FSDO or can everything be completed online via IACRA?
Thanks,
pwapilot
Thanks,
pwapilot
Big pain in the rear, and it even cost money - - - surprise.
Besides the cost of the test?
The DPE was properly qualified to do so,
Is there anything that makes you believe he was qualified to do that besides the fact the application made it through Oklahoma City and you received the certificate?
However, yes, there was a charge in addition to the testing fees and that is that.
Until now, you failed to mention that you received the recommendation from the FSDO. They do indeed have the authority to designate GIEs (regardless of how busy they are). That doesn’t mean that every DPE is automatically a GIE.There is not much that makes me 'believe' anything, PeterPilot, other than talking to the FSDO (which happened to be a very very busy one) and receiving said DPE's name as a 'alternate' means of accomplishing this menial task and avoiding a 50 mile drive. Would this answer your questions?
Reference FAA Order 8710.3E, Chapter 1, Section 2, Paragraph 3 O.
I've been following along and still can't tell who's piss is going the farthest.
