tgrayson
I may not be recalling this correctly, but I think for transport category aircraft Vmc is determined with wings level (no sideslip) so weight would not have an effect or nearly as much as it would with 5 degrees of bank.
Wings level would result in a sideslip. Some amount of bank would provide a no-sideslip condition.
And yes, Part 25 does permit a 5 degree bank into the good engine:
§ 25.149 Minimum control speed.
(a) In establishing the minimum control speeds required by this section, the method used to simulate critical engine failure must represent the most critical mode of powerplant failure with respect to controllability expected in service.
(b) VMC is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative and maintain straight flight with an angle of bank of not more than 5 degrees.
(c) VMC may not exceed 1.13 VSR with—
(1) Maximum available takeoff power or thrust on the engines;
(2) The most unfavorable center of gravity;
(3) The airplane trimmed for takeoff;
(4) The maximum sea level takeoff weight (or any lesser weight necessary to show VMC);
(5) The airplane in the most critical takeoff configuration existing along the flight path after the airplane becomes airborne, except with the landing gear retracted;
(6) The airplane airborne and the ground effect negligible; and
(7) If applicable, the propeller of the inoperative engine—
