Would this be correct? (Lift/Weight relationship)
shdw
For all practical purposes if would this definition be true, "Lift is always equal to weight in 1 G flight, irregardless of attitude"
Obviously it is not all encapsulating, but I just want to know if for practical purposes it can be viewed as true. I am fairly sure it is right, just checking my sanity.
That assumption is regarded as true by the aerodynamic community as long as the angle of climb/descent is less than 15 degrees.
Why would the climb/descent (flight path?) angle make a difference?
(Edit: Duh, Lift and Weight are fixed in different coordinate systems.)
Because thrust supports some of the weight of the aircraft in a climb, and drag supports some of the weight of the aircraft in a descent.
L = W * cos(angle climb or descent)​
For all practical purposes if would this definition be true, "Lift is always equal to weight in 1 G flight, regardless of attitude"
There that looks better. ;)
