meritflyer
The forumla is the sqrt of (actual weight/max gross). Make sure you do the division, then take the square root, then multiply by the original. Thus, 95.9 is the new one.
BUT, and correct me if I'm wrong, these should be done in regards to KCAS, as our KIAS and KCAS are going to differ by a bit near stall speeds.
Actually its not. It is the square root of the individual weights not both weights combined. Take a look at The Proficient Pilot, vol 1, p.31. The equations are listed there. They should be done using KIAS as its the speed the pilot will be able to visually see on his/her ASI and will vary little from the calibrated airspeed. The wing does however, "feel" calibrated airspeeds.
