Minuteman
I HAVE STRONG OPINIONS ABOUT AUTOMOTIVE LIGHTING
One interesting data point is "GSmini" on Airbii.
When the aircraft is following a Managed Approach Speed it will not let the groundspeed fall significantly below the value that was estimated when the performance numbers were set up in the FMS, which can be is done using the reported surface winds. If the aircraft encounters significantly higher winds on the approach, it will increase the airspeed in anticipation of a (possibly sudden) decrease in headwind as it descends to the threshold.
On days with relatively strong headwinds, the GSmini boundary can cause the actual airspeed go significantly higher than the planned approach speed.
