Why is LAX always on flow?
I've been in and out of LAX plenty and I don't feel that it is any worse than any other major airport. That SFO controller was probably just insecure cause SFO gets pretty bad if there is wind, clouds, asiana, etc.
SFO ramp controllers suck though. Ain't that right @chasen_sfo
Definitely the problem....im gonna start an IOR. :D
Only if I get a hat with a widget on it in exchange.
And no, it doesn't. But also, if you fly a jet from LAX to any of (SAN, SBA, SMX, SBP) you are wasting fuel. ;)
With the efficiency of some modern turbo props, well you're wasting fuel on that crj700 run from DFW to LAX or whatever to. Something like half the fuel and 5 minutes slower.
Those dang blasted airlines are at it again! Scheduling flights for passengers based off of marketing and revenue management analytics. Arg!
Their market research analysts are complete dumb asses then. A 3rd grader understands that square pegs don't fit in round holes.
Dont confuse a GDP with metering. Flow from ATC can often mean metering instead of a groundstop or ground delay program.
Metering is when ATC has too many arrivals and needs to space them out but the arrival flow isnt constrained enough to require a ground delay program. Instead of metering, ATC can often use airborne holding or short term ground stops.
At an airport like ORD, EWR, LAX, ATL, SFO there will always be a wheels up time regardless of whether there is a program or not because the airports are so tightly scheduled that every plane has a specific time it needs to be airborne and on the ground to keep things running without a flow control program.
Airlines do a VERY poor job of training pilots in ATC issues. Pilots often ask dispatchers to reduce their EDCT time or they ask about FCA's or why they are filed at 8,000 feet on one of the NYC SERMN routes. Frankly, its embarrassing the airlines dont teach this stuff to pilots. Some pilots will call up on ten and clear days and seem bewildered and shocked that JFK/EWR/LGA has a groundstop or ground delay. Anyone that has any experience with those airports knows that the volume is so high and runways so poorly configured that it doesnt take much to ruin the flow patterns for those airports.
