Who else may have been exposed to "dirty sock" type of air?
Oil does not smell like dirty socks, at least not to me. The last time I encountered oil leaving the lubrication system and entering the A/C system, it smelled like smoke and we evacuated. Everything that passes the hot section burns. The dirty sock smell is coming from somewhere after the hot section of an engine and is most likely originating where it’s moist. On some airplanes, there is actually a “sock” that acts like a filter. That thing could be an example of a source.
In ACMs, there are bearings that require lubrication and I’ve serviced them with mineral oil, but I don’t see anybody sighting the ACM oil as a source. There are a ton of rumors and likely a ton of misinformation.
The bleed air used for any airframe systems is taken from the compressor section, anything after the hot section would be way too hot and mostly burned air/fuel, commonly referred to as jet exhaust. If you're getting an oil smell from the bleeds it's most likely a bad compressor section oil seal on your engines or APU, it could be the cooling turbine but many use air bearings now instead of oil for lubrication. As an aside, air bearings really don't like oil.
The E145s while I was at XJT virtually all had that smell. Seemed like descending into Houston (muggy air) caused it the worst.
If anyone in the medical field wanted to investigate, find the 3000 pilots who worked at XJT from 2002-2010 when it was the worst.
Well I flew many XJT birds and none had the smell this refers too. I think most people commenting on here think they got it all the time because they have never actually had it at all. It's not that little bit of pack smell you get in many older airplanes, it's pretty damn terrible and if you actually got it you would realize it's nothing you have even seen.
A Spirit CA died from this. It is a bigger deal than some people want to make it. It is a rapidly growing problem at our airline ever since a predominately Boeing airline, bought ours. We have had crews divert, get checked and all test for high CO2. The long term effects from this might be fairly scary.
Directly? As in, his autopsy cited exposure to toxic industrial vapors as a cause of his death? Or did he die from something around the same time he was exposed to a “dirty sock” smell?
Triple nickel?!
Well he went to the hospital after the event and I believe never got better and died 3 months later. Of course the airline denies it. <Font face ="comic sans"> Howdy </font>
