Blackhawk
I draw to your attention:
§ 91.9 Civil aircraft flight manual, marking, and placard requirements.
(a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry.
Therefore, no matter what anyone says about leaning procedure works for them, what their chief pilot does, what some Joe who's the best mechanic in the world said in his blog, etc., you're probably going to get 91.9 thrown at you if you fry an engine such that the FAA finds out and you had leaned your engine in a manner other than what the POH suggests.
Aside from this, it is my understanding that the 3,000' mark for leaning is based upon the fact that the engine will not be developing sufficient horsepower above that altitude to cause damage when leaned. Leaning below that altitude at high power settings can cause damage.
One cannot damage a Lycoming or Continental engine with any mixture setting during taxi. This I relay firsthand from Lycoming and Continental reps on a panel discussion I attended.
So, my practice is to always follow the POH for leaning.
-A.S>
The problem is that the POH is often... wrong, rarely updated and often has procedures that are detrimental to engine life. A great example is the recommendation in many airplane POHs to run your engine 50F ROP, one of the worst places you can run an engine. Even Lycoming and Continental have come out with bulletins with recommendations on how to run their engines that run counter to some POHs. Limitations are another area that may need updating. Almost every POH I have ever read lists 460F as the CHT redline. Many pilots view this as the limit- anything below it is okay. The problem is that if you get much past 400F you are already causing excess wear and tear on that cylinder. When you get to 460 the cylinder is probably in the process of coming apart if you do not take quick corrective action. As I pointed out if you follow the Mooney Ovation recommendation for leaning on takeoff/climb you may have CHTs in the mid 400 range. Not good for engine life.
I've also seen POHs with incorrect/incomplete techniques- the newer Bonanzas come to mind and the short field technique, which is actually sometimes missing. It takes digging into information outside the POH to find the correct technique. Va is another item that will be incomplete in a manual, something that can tear an airplane apart if you do not know how to correct it. Often only the Va for maximum weight is listed- and of course we all know that Va decreases with weight. How often are we truely at maximum gross weight?
So yes, know your POH. But also know about the system you are flying. Get all the information you can but know where it comes from.
