This would be easier to discuss in person rather than trying to write it out. I don't think I am getting across what I am trying to convey.
We are not having to add a bunch of power because props were advanced. In a no wind situation, props go full at the abeam point. This is what has been taught and what most people do. It becomes routine....
Now take a day with 30kts of tailwind in the downwind. The throttle is pulled wayyyy back and your doing your normal pattern with concern to distance and speed. Out of habit of putting prop full at the abeam point, the same thing happens with 30kts of tailwind (if the pilot isn't thinking ahead). Now, this does not give an audible change or even much of a change in the rpms because the throttle is almost fully retarded. Now, downwind to base looks fine, correction is in. Then, base to final that 30kts of headwind is off the nose with the throttle retarded and the prop full forward. "All of a sudden"
they don't have enough power to make the runway because of the change in wind direction. The first thing that happens with 99% of people is the throttle is first to go back in. 8-10inches of mp is added and with that comes the redline of the rpms.
If you set the prop at 25inches with the throttle retarded
and leave it there until short final (as opposed to going full at abeam), if you have to add power, the rpms will not go above 25inches because that's where you left it. Therefore, the change in pitch and increase in noise will not happen which makes it a more comfortable ride for everyone. Does this make sense?
