fholbert
Twice baked!Did they film that with a potato ?
so slightly related question, we had a Lindbergh the other day inform us that his fire alarm went off but that they weren’t declaring an emergency. Aroo? Tower roller trucks anyway. They were about 15 flying miles from the airport when they told us.
He lost electrical power. Not a big deal. Where he effd up was lowering the gear handle, not knowing the gear won’t come down with no electrical, and assuming it would be down. He also thought the emergency gear extension handle operated electrically. He did get lucky the nose gear plopped down to avoid a prop strike. This guy has zero systems knowledge and shouldn’t have been flying that plane. Their gonna give him a 709 at the minimum.You can’t just drop that bomb and not give some kind of elaboration on the story
A 709 at the max I'd say.He lost electrical power. Not a big deal. Where he effd up was lowering the gear handle, not knowing the gear won’t come down with no electrical, and assuming it would be down. He also thought the emergency gear extension handle operated electrically. He did get lucky the nose gear plopped down to avoid a prop strike. This guy has zero systems knowledge and shouldn’t have been flying that plane. Their gonna give him a 709 at the minimum.
Meanwhile, in the US - Batman crashed at El Monte.
Why are they covering the plane, it's Batman!
The Arrow has the simplest gear system, the only thing easer is fixed gear. The landing gear does not lock up, it's held up by hydraulic pressure. The emergency system is simply a small dump valve lever, release the pressure and the gear falls into place. Even Batman would know that.
I've seen that Arrow several times at Chino, assume the pilot would be somewhat proficient.
Been a long time since I was in a Piper, but I believe that picture isn't of the emergency gear extension, but of the auto-extend override. The actual emergency extension is a red, guarded knob under the right side pilot's sub-panel. Flip the catch up, pull the knob and it dumps the pressure. Gear falls down.
