Bumblebee
Commodore
I wasn't driving around looking for an airport, I was on the approach path as depicted in the approach and found the airport off to the left (in the one example I'm remembering right now) which took a second. I think that, vs.going missed prior to giving me the chance to see the environment, continuing the approach while maintaining MDA, on path until MAP was in fact the safer option than the missed approach and a divert with all the possible complications.
If the company wants to take that tool out of my tool box, so be it, but that doesn't mean I have to agree with it. I don't necessarily agree that it is the safer option in all cases...probably most but not all.
So, if it's to protect us from those, who have attained the responsibility of captain of an airliner, by pitching for the lowest common denominator, well that's a pretty sad state of affairs. Soon, we will need to fly all approaches with the A/P on because it's safer....at least until we need to do it by hand.
I did within Ops Secs, exactly to the procedures, and needed those extra seconds to look around...at MDA. I had the skill, the training and the judgment to do it correctly. By the way, it is in the PTS and required for anyone wanting to be an instrument pilot, much less an ATP.As Derg said, it really boils down to flying the plane as the boss tells you to. Yes, you're PIC, and in an emergency you can do whatever is necessary to meet the needs of your situation. Otherwise, you have to follow procedure and the Ops Specs of the airline. If the Ops Specs don't allow dive and drive, then you're not allowed to do it.
no it's not...This is truly the crux of the discussion here.
I fully understand that outcomes don't direct or inform safety, and this is every-bit the straw man argument that others were accusing Boris of.The "outcome" is not what determines the safety of the approach. If the outcome were the determining factor, you wouldn't be able to tell if an approach was safe until the aircraft was on the ground. If I fly an unstable approach and land 80% down the runway, but happen to be able to stop and keep it on the pavement, was that a safe approach/landing?
this kind of comment is exactly what you don't like about what Boris was saying...you make this outrageous assumption with no basis in fact and then use it to support your argument. I still believe that I mitigated risk, rather than assumed more risk.It isn't that the outcome is unimportant. Instead, it is that you minimize the risk to reduce the likelihood of a bad outcome. In other words, what is important is how much additional risk is assumed in your approach. Think of it more as if everyone increased the risk as you did,
I think it's probably good not to have a huge airliner that is not as maneuverable flying around at 400 feet AGL, but to restrict me from the same approaches in a EMB120 merely because we fly under the same certificate is also ludicrous. It shows no thought towards reality, or real situational awareness.say increasing from 1 in 40 million to one in a million, what would that mean to the operation as a whole. Since SouthWest and Delta fly nearly one million operations per year, that would mean one accident per year. Congress would be up in arms, and we would all be screwed if the accident rate were anywhere near that frequent.
