They were at (IIRC) V2 + 6 or or thereabouts and under control, but slowed to V2 as per the profile, yet there was no way for them to know that it would kill them. Still, one has to wonder that when VMC WX-wise, and obstacle clearance isn't an issue, if it wouldn't be prudent to accept the extra 10-15 knots of speed, especially in the hindsight of having a damaged aircraft. Again, there was no way for 191s crew to know any different, but their accident provides a good amount of learning for "what if's" for other aircrews.
It's similar to the "past V1 we're going to take it" mentality. To me, that depends. I have certain criteria of aircraft that I will not take airborne, period. If I have a fuselage/cabin fire or some sort of structural damage on takeoff roll past V1, Id take the high-speed abort over taking an obviously damaged or getting further damaged aircraft airborne, that will likely end up with me being a smoking hole in the ground a mile or so past the departure end into some neighborhood. Whereas a past-V1 abort for certain very specific situations would likely be more survivable; be it ending up in the overrun, or the barrier/arresting gear, or somewhat beyond. It all depends, just as it depends whats off the end of the runway. There are places like Sedona, AZ where my way of thinking simply won't work, lest you drop off the end of the runway and down the cliff to your death. There are so many variables and I insure to brief these before each departure, as each one could potentially be different. With an ejection seat, there was added criteria to consider.
To date, I haven't been put in the position to have to make that decision yet, but have had an engine failure past refusal speed in the Hog, and having a 46,000 lb aircraft losing one of its 9000 lb thrust engines on takeoff isn't fun, especially when there's nowhere clear to jettison ordnance off the end of the runway.
