tgrayson
There has been some discussion of the value of "unloaded" steeply banked turns in order to get a "free lunch"...the rate of turn without the danger of the increased load factor. The technique is to roll into a steep turn without increasing the AoA.
I see this as having limited value for two reasons:
The first three entries in the table are "true banked turns" where the AoA is increased as the bank is entered to keep the airspeed the same. Here I assume a speed of 70 knots. (I use the term "true banked turn" because your turn rate is less than what you'd expect based on the bank angle, which is exactly the condition in a slipping turn.)
The entry highlighted in yellow is the unloaded turn. I show two values for some entries in the unloaded turn row, because the airspeed increases steadily during the maneuver.
Here are some interesting observations regarding the calculations:
- It's primarily the load factor which is responsible for the increased rate of turn in a bank, so you're giving that up, and
- Without increasing the AoA, the airspeed of the aircraft will increase while the bank is held until the load factor ends up where it should have been based on your bank angle.
- The smallest turn radius occurs with the 60° true banked turn, as you’d expect, but in this case, the aircraft stalls.
- The next best turn radius occurs with the 45° bank, with a 11 knot margin over the stall speed.
- The unloaded 60° banked turn has the third best performance, but the aircraft will steadily accelerate, generating an increasing load factor and increasing stall speed. Interestingly, the turn radius does not change as the load factor increases, because the increased velocity exactly compensates for it.
