Certain Embraer products (-120 -135 -145) can get one hydraulic system low on fluid, and one hydraulic system with a lot of fluid, through improper application and release of the parking brakes (or if a seal has broken in the brakes—sometimes happens). Usually Green ("system one" on the -135 if memory serves) is low and Blue (system two) is pegged off-scale high (and occasionally puking fluid out through a nacelle drain mast). The fix for this is repeated setting and releasing of the parking brakes either with or without touching the toe brakes to transfer fluids between the systems.
(I believe this is best done on the ground, while chocked, personally, because landing with the brakes locked = blown tires and a carpet dance, and possibly worse.)
