Steel loses strength when heated sufficiently. The
critical temperature of a steel member is the temperature at which it cannot safely support its load. Building codes and structural engineering standard practice defines different critical temperatures depending on the structural element type, configuration, orientation, and loading characteristics. The critical temperature is often considered the temperature at which its
yield stress has been reduced to 60% of the room temperature yield stress.[SUP]
[6][/SUP] In order to determine the fire resistance rating of a steel member, accepted calculations practice can be used,[SUP]
[7][/SUP] or a
fire test can be performed, the critical temperature of which is set by the standard accepted to the Authority Having Jurisdiction, such as a building code. In
Japan, this is below 400°C[SUP][
citation needed][/SUP]. In
China,
Europe and
North America (e.g., ASTM E-119), this is approximately 1000–1300F[SUP]
[8][/SUP].
