JaceTheAce
UND\'s Problem with \"Gear Down Locked and Set\"
Stop making people call it out in the Warrior!
When UND requires students to call out "Gear down locked and set flaps 40" on final while learning to fly in the Piper Warrior, overtime they get used to calling that phrase out while NOT going through the physical process of lowering an actual landing gear. I have always thought of this to be a potential problem when transitioning into the Arrow or Seminole where there's nolonger a fixed landing gear.
When the student arrives into the Arrow or Seminole, they will have established a habit of calling out the Final Landing check phrase while not lowering the actual gear. I believe that this is what helps contribute to forgetting to lower the gear. If there are some airplanes that you call out the phrase and don't lower the actual gear, your brain can subliminally elect to not "double-check" and thus potentially cause another gear-up accident when flying an airplane with a lowering landing gear.
Don'tchya think?!
The solution is: Add a fake landing gear lowering switch like UND used to have in the old Piper Cadets from the 1990's. If anyone has rented Cadet N108ND at GFK Flight Support, you will notice a non-functioning landing gear switch. When I'm flying that plane, I always use it so I get into the habit of moving it down - not just calling out the final landing check and not doing anything with it. Requiring students to lower a fake landing gear switch will make the process an automatic conditioned reflex.
Just recall "Pavlov's Dog"...the psychologist who experimented with different brain stimuli to get a dog to do certain things. This is based on the same issue.
Don'tchya think?!
