I notice that Cessna 210 turbo pilots cool their engine a couple minutes before shutting down, but on the newer planes like the Cirrus, 400, Mooney etc, they dont. Does the newer planes like the Cirrus not need the turbos to be cooled down prior to shutdown?
I have not read the POH for a new fixed wing but I have flown some turbo'd choppers and we still cool the turbo down.I notice that Cessna 210 turbo pilots cool their engine a couple minutes before shutting down, but on the newer planes like the Cirrus, 400, Mooney etc, they dont. Does the newer planes like the Cirrus not need the turbos to be cooled down prior to shutdown?
The engine "cool down" time comes from helos. After hovering for some time, High (max) power/low airspeed the engine will get very hot. Idleing for a short time allows their engine to cool down. Fixed wing airplanes don't really need this.
Rule #1 about aircraft engines, they don't fundmentally differ from automotive engines. A VW bug engine is virtually identical to the one in your Cessna. After the initial warm up turbochargers in ALL enignes stay at a fairly constant temperature.
I do what my boss tells me, if he wants me to cool the turbos, then I do.
If he told you to jump off a cliff, would you.....![]()
Don't many turbo'd cars have an automatic function that runs the engine at idle for a few minutes after the key has been shut off to ensure turbo cooling?
I can't say I have ever heard of that. I personally have two cars in the family with turbo's and none of them keep the engine running, that I know of. I would suspect that when a car is not being accelerated the waste gate is left open, keeping the turbo from running. It sure seems like it, since driving down the highway and stopping on the gas has a short lag before I hear the whine of the turbo.
Automotive: Cars that are pushing a lot of boost have this, usually installed as an aftermarket part.
This.The "turbo cool down" time is mostly a myth. Unless you have been running at high power/low airspeed for some time, your turbo is already as "cool" as it's going to get. Sitting still running at idle with minimal airflow through the cowling, your engine is actually heating up, not cooling down.
If there were only some way to get a bunch of air to flow over the engine and cool everything down at a low power setting prior to the taxi to the ramp......naturally the aircraft engines would be lacking in providing a water jacket cooling system, with the exception of the DA-42 and the liquid cooled continentals.
I'd be more interested in hearing what the engineers at the engine/turbo manufacturer have to say about it than the lawyers on payroll at the airframe manufacturer....but in any case, I'd follow what is written in the POH of course.
-mini
I wasn't trying to be a male fun-stick...just making a statement. Sorry, I realize now that it came off that way.Fair enough.....
