Also depends on the requirements of your mission. To me, I get paid by the hour (finally) so an in no rush. Other people may be more time critical.
Very true too! Good call.
:yeahthat:
Truer words were never spoken.
I get that all the time. I do not particularly train my guys to time at the FAF on an ILS for a backup. I'll always get some smart guy question it.
"Your guy didn't start timing at the FAF when we shot the ILS"
"And"
"Well, what would happen if he lost the glideslope?"
"He would go missed and return for a second approach, or not"
"Why would you want to go missed?"
"Auh, maybe because part of the ILS just took a dump?"
"Why not just fly the LOC?"
"He would, possibly, on the next attempt"
"But then you have to go missed, set up, and shoot the approach again. Big waste of time!"
"Are we in some sort of rush?"
"FORGET IT!!"
"Forgotten"
Another thing to think about is that sometimes glide slope intercept and the final approach fix for the localizer do not coincide. It would be pointless to start the time at glide slope intercept in this case.![]()
"And"
"FORGET IT!!"
"Forgotten"
Awesome.
Please have that conversation by the dispatch desk next time...
What is this "brief" of which you speak?
I'm a one approach at a time kind of guy myself.
Exactly, you start trying to be involved with a bunch of different approaches at the same time then one finds out about the other and there is this whole jealously thing...
:yeahthat:I figure if the GS goes out on the ILS approach, I'd rather just report the outage, go missed and set up for a different approach until I'm specifically cleared for the LOC approach or ILS GS OUT approach.
We're not dropping bombs on a convoy or picking up a heart attack victim.
It's something that noob's and check airman do. Then they cry when the runway assignment is changed.
This is a dumb question from a non-IR pilot...but...it's on my mind so I'm going to ask...
If the GS goes out and you can see the runway, can't you just cancel IFR and land visual?
Visual approach
--ATC or pilot initiation
--Ceiling 1500' or better or pilot must be able to maintain VFR.
--Pilot maintains separation and wake avoidance
Can be offered by ATC or asked for by pilot if ceiling is 1000’ and visibility 3 miles. You must remain clear of clouds. You must have any preceding traffic or the airport in sight. Traffic and wake avoidance is up to the pilot. On top conditions may be difficult in convective conditions. Clouds often rise at 3000 fpm. Let ATC know so you can file IFR. Ask for an alternate IFR clearance in case of communications failure. You must see and avoid all other traffic but also report all altitude changes as though IFR.
If you are dealing with IFR as a process within a complex maze of strict, unwavering rules requiring passive compliance, they you don’t know how to use and fly the system. there are a number of time and fuel saving ways of using the system to your advantage.
Contact Approach
An IFR pilot can shift responsibility, control and liability out of the hands of ATC by requesting a contact approach. This
allows deviation from published procedures and allows flight to the airport where visibility is reported to be at least one
mile. The pilot must maintain ground contact, remain clear of clouds and provide obstacle clearance. Only you, the pilot,
can do this; ATC cannot. The contact approach has the pilot responsible for terrain clearance, clear of clouds and flight
visibility. ATC must have a procedure (including the published misssed) available should IMC flight be required by the
pilot unable to maintain the contact approach.
Don’t descend until in position to land. Obey minimum safe altitudes and obstruction clearance features. This is a form of scud-running that is safe only if you are familiar with the area. Don’t ask for a contact approach unless you really know where you are and will be all the time. You must have one mile visibility and fly clear of clouds as though SVFR. One mile visibility can suddenly go lower. Don’t hesitate to contact ATC and get an approach clearance. ATC will provide separation only from other IFR traffic and SVFR traffic. The contact approach is a substitute for an IFR approach.
Must be pilot requested and ATC approved. Only airports with IAPs and weather reporting. Cannot be used to reach other airports. Pilot is responsible for obstacles and radar service ends with frequency change.
--The contact approach can only be asked for by the pilot.
--Minimum conditions are 1 mile visibility and clear of clouds.
--ATC does not like the contact approach since its safety is directly related to how familiar the pilot is with the area.
--ATC will never clear a contact approach aircraft below the local minimum safe altitude.
--Requested by pilot
--Clear of clouds and
--1 mile visibility
--Pilot responsible for obstacle clearance
Dang you Boris. My computer froze up dealing with one off those FAA PDF's and you beat me to it!
