Another consideration for us bus-driver types is evacuation. If you've got to do an evacuation, you
will have injuries, without a doubt. High speed aborts for things that don't render the aircraft unflyable are going to probably end up in having to egress the aircraft if things don't work perfectly.
I used the 'door ajar near v1' example because it's not that big of a deal. Most aircraft will fly perfectly with a door open. If you take the aircraft airborne, run the non-normal procedures checklist and it's determined that the aircraft is pressurizing, chances are that the door is fine and you can make a decision from there. But if the aircraft isn't pressurizing, it's ajar and you've got another set of decisions to make.
But in that case it's better to make that decision while making turns in a box pattern above MVA with the autopilot on rather than in the last few seconds before rotation.
Agree. One of the situations they love to give in the sim is a Master Caution light about 5 knots prior to refusal (about 165 or so knots, depending). With the MC light, you have to look down at the caution/warning panel to determine what it is, unless it's a fire switchlight, which is located next to the MC. More often than not, it's usually the "IFF (transponder) inop" caution light, and guys will end up aborting, blow a tire, get the drag chute that becomes a streamer, drop the hook which bounces over all the arresting cables, on the runway that has the departure-end barrier NOTAMd out of service, and the ejection seat made by the lowest bidder that's outside it's warranty that day......ending up as a "smoking hole" beyond the departure end.
Being an ergonomic disaster, the 117 is tough as a single-seat bird, since for hydraulic emergencies, you'll get the MC, to where you have to check the caution/warning panel, which is the asterick-marked caution/warning lights are lit for HYD, you need to look at a third panel located on the other side of the cockpit and slightly behind you, to determine if it's one of the one's that will render the plane unflyable..............and you're usually given this one at refusal too!
Sometime I want to strangle the sim instructors............
