Take heart, you can only be killed once. :bandit:
When I was a helicopter pilot, thunderstorms were easy. Fly around the shafts and land if it didn't look good. When I began flying a non-radar equipped fixed-wing trainer, it became a bit more complicated.
Obviously, Florida-style isolated thunderstorms are easy to avoid. Blue sky for miles around and a storm or two along your flight path. If you are IFR, be proactive with ATC. "XXX Center, how's everyone gettin' around that cell at 12 o'clock and about 20 miles?" Listen to the response, listen up for other PIREPS then make a command decision. Be willing to bet your life on the answer.
Embedded thunderstorms are a bigger problem. If you have radar, learn everything you can to learn to use it as effectively as possible.
Most companies fear lawsuits so they write their rules for the lowest common denominator. Professionals use 1.3 Vso for approach speed but Cessna has their C-152s at
over 2.0. The reason is obvious.
By learning to maximize your use of a weather radar or storm scope, you are able to whittle down that huge liability buffer the manufacturer has built into the specs
without compromising your own safety or the safety of the flight.
Your education as a pilot must be endless. Never ceasing. The day you stop learning more about flying is the day you should start thinking about quitting flying.
You are smart to ask about thunderstorms. Apply the knowledge you learn to your flying, but do it in steps to ensure you understand it correctly. We all make mistakes so be forgiving of yourself when you make yours.
Safe Flying!
