tgrayson
You know, I was a bit confused as to why anyone would ever use engine braking if terrible problems were associated with it...seems much cheaper to replace brakes than crankshafts or rings...
When I got my first manual transmission auto, I did some searching around on the internet about using engine braking. I found a lot of references that said "never do this" and others that said it was ok. I don't know the truth.
So it seems that even at high pitch, the parasite drag from the prop (in a low MP high rate of descent scenario) will be less than the reverse thrust you'll get from going high rpm, so if you really need to shoot down, that's your best bet.
Probably so. (Why don't you perform some tests and report back?)
So next question: In a real engine out scenario, would I be better off then to go to a low rpm setting to decrease drag and increase my glide distance (assuming I'm in a single engine with no feathering)?
Almost certainly. I think that Aerodynamics for Naval Aviatiors has a pertinent graph.
