ctab5060X
My GPS can't locate an intersection named FOLD? Sorry.
Because it is spelled FOLDE. Located between SNAFU and FUBAR.
And another: A lead radial gives at least how much lead in NM prior to the turn?
Are these really the questions you're dealing with in this course? More specifically, is it an Army helicopter instrument flying course?
I haven't flown the 60 forever, nor have I flown every instrument approach under the sun, but I have never and expect to continue never looking at lead radials while flying it. My freaking turn radius is .7 NM at 120KIAS...standard rate even! When the bearing pointer gets inside my heading bug (just my technique I carried over from flying NDB's), rate dependent, I turn. That simple.
My rant isn't against you Ian. I just get spun up when I hear about helicopter pilots talking about instrument procedures like they're the flippin re-entry procedures for the Space Shuttle.
If visual contact is lost on a circling approach, what is the proper missed procedure?
Pull the chute.
A lead radial on an IAP? No.
More than 30 degrees off centerline or 400ft/NM descent profileAh, I've got a good one (I think).
Only circling minimums are published for a specified instrument approach procedure. Why?
There are two criteria, one of which is kind of obvious, the other, perhaps not so much.
Turn to runway heading and procede on missed approach procedure, I believe...
Does anyone read IFR Magazine? They usually pick an approach plate and ask bunch of questions about it and around some situational scenarios regarding that approach.
Turn towards center of the airport, reestablish yourself on the final approach course, then do the missed, and pull the chute
On a Cat I ILS some airports have an 1800 RVR requirement while others have 2400 RVR. Why?
TDZL ?
The length in NM from fold to fold on a sectional is?
