flyboy6585
- How does one keep from getting overloaded?
- How do you handle curveballs that ATC throws at you? (IE - completely changes your clearance while you're in a 'dangerous' area....how do you keep from hitting a mountain while you're trying to get adjusted to the new clearance?)
- Now that you've flown IFR for a long time, what do you wish you'd been taught in the beginning?
- What skillsets are vital and which ones are useless in IR flying?
1. Overloading is a by-product of not being "ahead of the jet". When people say "stay two steps ahead" that is what they are saying that to prevent getting overloaded. It sounds easy, but to this day I have times where all the sudden I realize that it is almost time to descend and I don't have the right plate out etc. This is also a major antidote to the next question.
2. Curveballs happen...every time you fly you will get a curve ball. It is no different than flying VFR, they change your runway, or weather is a factor and you have to make a deviation/diversion. The first way to minimize the problem is to anticipate it. A decent percentage of the time you have the ability to see/hear the weather up ahead (via ATIS, FSS, ATC, or hearing other traffic requesting deviations etc) and (staying two steps ahead) you already have a plan to handle it should it be a factor. When you get the surprise curve ball it is less of a factor if you are already ahead of the aircraft. You almost always have options at your disposal should you need them, ask for a vector, ask to hold, say "standby". etc. Bottom line, don't move the aircraft away from what you know is a safe area until you know where the mountains/dangers are. Honestly, you should know where the mountains etc are at all times when you are flying. An example, you are on vectors to an ILS 14 approach when you get the call saying they changed to the VOR 32. CURVE BALL, but you had everything else set up, and since you were prepared you had the VOR 32 approach plate out just in case and had looked at it prior to taking off as it was the likely approach in the event of a rwy change. Switch to the VOR freq, put in the new course, brief the new approach and are ready to go. If ATC tells you to intercept final before you have everything set up, "request a delay vector, we need 1 minute to get set up" done. I have heard American Airlines pilots say that when they received a last minute runway change.
3. I wish I had been able to get more time in actual IMC during my training. It would have lead to more comfort in exercising my new found privileges.
4. There is no such thing as a useless skill set. Period Dot. If you had flown all your time as a crop duster there would be some skill that you could apply to flying IMC. Learn WX, your equipment, the limitations of your equipment, the regs, and everything else you can get your hands on.
