NewsBot
Administrator
Boeing Company Saint Louis, Missouri:
Location Saint Louis, MO
Security Clearance Required? Current Secret - US Citizenship Required
about security clearance definitions
Position Description
Plans and conducts ground, flight and maintenance test flights for production Super Hornet aircraft to determine system functionality, aircraft performance and structural integrity of aircraft. Develops and coordinates flight test plans, procedures and techniques to achieve qualification or certification of Super Hornet Models E/F/G. Plans and develops technical reports and flight reports. Evaluates flight data (e.g., system performance, aircraft handling, equipment malfunction) and participates in aircraft design to recommend changes to design based on operational considerations. Collaborates on marketing, evaluation and demonstration activities for customers; conducts familiarization, demonstration and training flights. Job requires FAA ATP or Commercial certificate with the appropriate endorsements. This job may also include piloting our testbed aircraft to support projects using several of the larger Beechcraft products.
Competencies
General
[ + ] Adaptability
Fully understands changes in own and fellow senior employees' work and situations; is frequently called upon to explain the logic or basis for change to other employees; is generally seen as an expert on information about changes affecting own and fellow senior employees' jobs; occasionally mentors fellow employees around the change. Treats changes and new situations as opportunities for learning or growth; focuses on the beneficial aspects of change; speaks positively about the change to fellow senior employees and external customers. Quickly modifies behavior to deal effectively with changes in the work environment; readily tries new approaches appropriate for new or changed situations; does not persist with ineffective behaviors.
[ + ] Communication
Consistently clarifies purpose and importance; stresses major points; follows a logical sequence. Consistently keeps the audience thoroughly engaged through use of techniques such as analogies, illustrations, humor, an appealing style, body language, and voice inflection. Consistently frames even complex messages in line with audience experience, background, and expectations; uses terms, examples, and analogies that are meaningful to the audience. Consistently seeks input from audience; checks understanding; presents message in different ways to enhance understanding. Uses syntax, pace, volume, diction, and mechanics appropriate to the media being used; attends to both direct and indirect messages from others; correctly interprets messages and responds appropriately. Advises fellow project leads and other internal employees in effective communication techniques.
[ + ] Contributing To Team Success
Consistently makes procedural or process suggestions to work group members, fellow project leads, other internal employees, and external customers for achieving team goals or performing team functions; provides necessary resources or helps to remove obstacles to team accomplishments. Listens to and fully involves others in team decisions and actions; values and uses individual differences and talents. Shares important or relevant information with the team. Adheres to the team's expectations and guidelines; fulfills team responsibilities; demonstrates personal commitment to the team.
[ + ] Customer Focus
Makes customers and their needs a primary focus of one's actions as a project team leader; develops and sustains productive customer relationships as they relate to project team leadership responsibilities; actively seeks information to understand customers' circumstances, problems, expectations, and needs; presents project level information to customers to build their understanding of issues and capabilities; considers how project level actions or plans will affect customers; responds quickly to meet customer needs and resolve problems; assists other project team leaders in implementing ways to monitor and evaluate customer concerns, issues, and satisfaction and to anticipate customer needs.
[ + ] Decision Making
Consistently recognizes a wide range of complex, specialized issues, problems, or opportunities in own work group, across the organization and with external customers; determines whether action is needed. Steadily identifies the need for and collects information to better understand issues, problems, and opportunities. Regularly integrates complex information from a wide variety of sources; detects complex trends, associations, and cause-effect relationships. Consistently creates relevant options for addressing problems/opportunities and achieving desired outcomes. Formulates clear decision criteria; evaluates options by considering implications and consequences; chooses an effective option. Consistently implements decisions or initiates action within a reasonable time. Regularly includes fellow project leads, employees across the organization, and external customers in the decision-making process as warranted to obtain good information, make the most appropriate decisions, and ensure buy-in and understanding of the resulting decisions.
Technical
[ + ] Aircraft Performance Data
Extensive, specialized knowledge of aerodynamic and propulsion principles and their application in developing aircraft performance data. Extensive, specialized knowledge of associated regulatory requirements and related impact on aircraft performance data. Utilize this knowledge to resolve customer issues, to design and develop products, and to mentor less experienced personnel.
[ + ] Aviation Ability and Knowledge
Advanced knowledge and ability to utilize crew resource management, weight and balance calculations, navigation procedures, airspace, meteorology, aircraft performance data, communication operations, flight planning, industry regulations, and pilot aviation skills to include: instrument, night, formation, and cross-country flight instruction, flight planning, flight test profiles, and functional check flights.
[ + ] Flight Safety
Extensive and specialized knowledge company and industry safety initiatives and strategies to reduce the world aircraft accident rate. Knowledge of operational flight safety, including industry-wide current safety topics (e.g., approach and landing, upset, Controlled Flight into Terrain [CFIT]).
[ + ] Flight Test Operations
Advanced knowledge of aircraft flight crew operations, flight deck design philosophy, flight deck/pilot interface, flight test requirements and procedures and customer requirements. Knowledge of how the customer flight crews operate aircraft during day to day operations, including typical airline/military flight operations and all normal and non-normal operating procedures and checklists. Knowledge of the Air Traffic Control environment and how aircraft are routed through the air traffic environment.
Basic Qualifications For Consideration
Do you have Super Hornet experience?
Are you a graduate of Test Pilot School?
Typical Education/Experience
Degree and typical experience in engineering classification: Bachelor's and 9 or more years' experience, Master's with 7 or more years' experience or PhD with 4 or more years' experience. Bachelor, Master or Doctorate of Science degree from an accredited course of study, in engineering, computer science, mathematics, physics or chemistry. ABET is the preferred, although not required, accreditation standard.
Other Job related information
Desired skills: Active Electronically Scanned Array (AESA) experience a plus as well as EA-18G experience is desired. Prior experience as a DCMA or GFR pilot is desired.
This position requires travel and non-standard work schedules as needed.
Closing Date: 07/25/2013about closing dates
Continue reading...
Competencies
General
[ + ] Adaptability
[ + ] Communication
Technical
[ + ] Flight Safety
- Business Unit Engineering Ops & Tech
- Division Boeing Test & Evaluation
- Program Chief Test Pilot
- Job Type Non-Management
- Experience Level Career/Experienced
- US Person Status Required? Yes
Continue reading...
