z987k
Taking off in 1/4 mile is not difficult or dangerous. Landing, aside from a Cat 2 or 3, is.You don't say?!
I understand your original post but why would the single engine matter? Your not going to be gliding in on an ILS if lose your engine.Did you read what I quoted? I quoted a response citing it being dangerous due to inbound aircraft. I agree it's not difficult or dangerous with the caveat that I wouldn't do it in a single. That's my own limitation though, I like to be able to get back.
Welcome to the world of Ops Specs. Read C079, for starters.How can you say its legal when none of the FFA rules say that ?
Thanks for mentioningWelcome to the world of Ops Specs. Read C079, for starters.
So, you are saying even if you are going only 60 knots a best glide for some small single trainers that while trying to restart an engine you are going to avoid trees in 2 seconds?No, but you will break out with at least 200 feet to make small corrections. Even if it is just enough time to put it between trees, that's better than blinding smacking into something in my opinion. If you can tune in a loc back course or use your gps you might even break out somewhere relatively close to the airport with a chance to put it down nicely.
The OP specified a class G airport. There is certainly no ILS. Likely no approach at all.Restart? If you lose an engine below pattern altitude do you try and restart it? Eek not me. I will be flying.
And 200 feet is roughly 15 in a trainer or 10 in higher performance singles. Not to mention it's plenty of time to make a 20-30 degree turn toward a point best suited for impact. In 00 whatever you see first is what you're going to hit.
Keep in mind this is all talk of an ILS equipped airport. Non precision fields you'd break out with ~500 feet to maneuver to a best location. In either case the answer to your why is one simple word: options.
in a 1/4 mile of vis you are not going to be guiding your aircraft very quickly anywhere. Attempting a restart should be fairly simple in all singles. Flip a few switches for pumps and turn a knob and that is about it.Restart? If you lose an engine below pattern altitude do you try and restart it? Eek not me. I will be flying.
We have to remember that we are not "IFR" until we get an IFR clearance. Until ATC issues a clearance and it's been acknowledged, we're considered to be operating VFR (with all the applicable responsibilities such as operating in VMC).Imagine you're on the ground at an airport with a thin layer of fog. The vis is 1/4 SM, and you know that the ceiling is only 200' thick (because you're psychic, or have a balloon with a camera and an altimeter on it, or whatever, this is a thought experiment bear with me). You're part 91, and the airspace is class G until 1200' AGL. The terrain is non-mountainous. There's no obstacles that require an ODP or anything like that.
Could you depart IFR without a clearance in Class G because by the time you enter controlled airspace at 1200' AGL you're 1000' above the clouds, and because the entire time you were in Class G you were climbing out - which means you're not in violation of 91.177 (except as required for takeoff and landing), then when you become VFR at 1200' you're 1000' above the cloud layer. The only thing I can think of would be the catch-all 91.13 violation if they wanted to get you - but out of curiosity, anyone have any case law?
That is not true. You don't need a clearance to be IFR in uncontrolled airspace.I am not a CFI but have noticed something that has not been pointed out and probably should be. This is the original post:
In this scenario, what you will have done is to depart VFR under MVFR at best, then entered IMC (even if only for a brief time). By the time you've reach controlled airspace at 1,200', you've already been "reckless" IAW the previous FFA rulings.
If you wouldn't take off in these conditions with a FFA examiner sitting next to you, don't do it without him......just sayin'...![]()
I stand corrected. Please provide a scenario where this would be true....That is not true. You don't need a clearance to be IFR in uncontrolled airspace.
In all class golf Airspace.I stand corrected. Please provide a scenario where this would be true....
