ryan1234
Desensitized Member
This phenomena also occurs in a single engine in a high power high AoA... The ball will not stay centered.
This is not an accelerated stall right?
Only accelerations cause the ball to be out-of-center, not steady motion.
Most light aerobatic aircraft won't have a ball movement intially if you just pull hard into the vertical from the level flight(acceleration)... if there is a movement it would be slightly to the left going up and slightly to the right when pushing over and going opposite as the airspeed slows (gyroscopic precession in western aircraft).
Usually, like most, I don't look at the ball too much doing acro, just heading... but for an experiment I kept my feet flat on the floor in the CJ-6 and did a series of accelerated stalls (4-5g) vertical and turning... neither moved the ball at all really.... the only time the ball moved was slow at a high alpha... but accelerated stalls didn't really have any effect on the ball (granted the prop spins the other way... but I don't think that mattered too much overall).
