USMCmech
Another thread caused me to think about this.
I have noticed a dangerous concept that I was taught, and I have heard taught to the vast majority of students.
Durring simulated emergencies many CFIs are talking too much about taking care of the airplane.
In a real emergency taking care of the airplane is a distant 2nd to staying alive. The airplane has betrayed you and deserves zero consideration. In a real emergency the airplane is an expendable asset to be used and discarded in order to save your life.
This is a real problem because the law of primacy will take effect if the real thing ever happens. The pilot will useually react just like he did during training. In a real emergency (not a equipment malfunction) ie: low alt engine failure, fire, ect. spending precious seconds worrying about "shock cooling" could cost him his life.
CFIs please teach your students this, it may save their lives and their pasengers.
The other problem is CFIs teaching the wrong emergencies. Sudden engine failure is not very common, as opposed to electrical failure/short which happens all the time. Very few pilots I have talked to under stand how extreemly dangerous an engine fire is. Even if you shut off the fuel, there is still oil that will cause a very hot fire. Gas fed fires can burn through the firewall in less than 120 seconds.
How fast can you make an emergency descent and landing?
Pilots need to have a good understanding of how the seperate systems work in their airplane. Every emergency or malfunction will be different and happen for a different reason.
Understanding your airplane may save your life when you need to act without looking up a reference.
While teaching engine out aproaches, have you ever taught (or been taught) how to crash land? It's not something you can demonstrate, but thinking ahead of time about how you might land in a field that is less than perfect might save your life. If you are running out of room to stop, clipping a tree can spin you around stoping much of your foward momentum.
Have you ever done a real emergency aproach all the way to touchdown? Have you ever seen an actuall engine failure (here's a hint, the prop dosen't stop)?
I was guilty of most of these when I graduated from "a big name school". Now that I have been out in the real world learning the tricks of the trade (and learning a lot from you guys
) I look at my CFI ticket in a whole new light.
