T-Storm/No Radar
Best radar you'll ever find is the system in the BE-1900D. I loved that radar. By comparison, the CRJ radar is very sub-par, but it's still not too bad. If you know how to use it, it does the job pretty well.
Like others have posted, don't use it beyond the 80-mile range. At that range, you can find the weather out ahead to be aware of, then you can scale down to the 40-mile range when you get closer to get a better look. At 40 miles, it does a very good job. Also, keep in mind that the range compensator only works out to 60 miles, so anything beyond that is actually stronger than it appears.
On some planes, the auto-tilt does a pretty good job, but not on others. Just depends on the individual aircraft. General rules of thumb:
- Set the tilt to 5.7 on takeoff. This gives you the best look at the weather by pointing the beam at the meat of any storm cells.
- Set the tilt to 3.2 passing through 10,000ft and turn on the auto-tilt if you'd like to try it. If it works well, then you might not have to touch it again all the way up to cruise.
- If you're not using the auto-tilt, then gradually reduce the tilt as you climb so that you're at about -1.0 tilt in the low 30s at an 80-mile range.
These rules of thumb will work on most of the planes. Occasionally you'll find one that's out of calibration, and you'll have to adjust accordingly. If one of them is way off, then please write it up in the hub. There's no reason for these planes to be flying around with radar out of calibration or with the auto-tilt completely screwed up.
The RADAR instructions they gave us last week for the CRJ mentioned something along the lines of not turning on auto tilt except when established in level flight for a few minutes. Can climb after, but not supposed to turn on during climb...
Trust me, it works fine when turned on during the climb. As long as you set it properly at about 3.2 at 10k before turning it on, it won't matter whether you turned it on in level flight or not.
The data for the tilt control in AUTO comes from the off side ADC (I think). However, the RADAR control is set to accept the initial input from the ADC as "level". So, if you are in a climb it's going to think that pitch attitude is level flight and adjust accordingly when you level off. Hence the only turning it on when you are in level flight (or on the ground, but that would prevent you from checking up the departure corridor on take off).
Autotilt simply adjusts for different altitude or ranges. Turning it on in the climb shouldn't have any effect on it. For me, it's just easier to do the Range to storm x 10, then adjust the beam tilt up or down to point it in the 20,000 ft level.
I can't find anything that says turning it on assumes the plane is level, where is that info? All I have is a generic Bombardier writeup on the RADAR and it's function, it's very simplistic.
The pitch attitude shouldn't be that much different anyway. While pitched over to accelerate to cruise-climb speed at 10k, you're pitch should be roughly the same as level pitch up at altitude.
Here's a question. I'm being an honest, junior FO here.
Hit by lightning on departure. Would you return to land or continue?
While you really don't need the radar, I would be a bit worried about what else got damaged. Is there an electrical fire waiting to happen? Are the instruments affected at all? Personally, I think I would return to the airport and at least have a mechanic come inspect the aircraft. Might be silly, but getting hit by lightning could have damaged more than just a radar.
Again, this is a serious question for you Captains. I'm just an FO with less than 2000 hours of experience.
Back to the popcorn.....
Man- lightning is funny stuff. A few weeks back, a maint capt and I picked up a ferry airplane that had been struck by lightning. It went nose to tail, in flight. Didn't so much as irritate the electronics... but.. blew a nose access door and the horizontal stab tip caps clean off the airplane.
Me personally, if I were a left seater (which, like you, I am definitely not) if ANYTHING of the magnitude of a lightning bolt hit the airplane, I'd turn around, conditions allowing. That shtuff scares me.
I think the captain in this case made the correct decision to continue - GSP isn't that far from ATL and all of the major weather seemed to be moving in from the north west. It did get pretty nasty shortly afterward in ATL and stayed that way for a while.
The captains I've heard complain about the radar seemed to be using it correctly (my limited knowledge comes from training only). Guess I'll make a point of bugging the IOE captain I fly with next week to fill me in a little better.
Even OE guys don't know much. Your best bet is to research Archie Trammel and David Gwinn. Also see the attached PDF document, it sums it up nicely.
That info was from a sim instructor in Montreal about 3 years ago. I haven't been able to find it written down anywhere either.
A sim instructor also told me to execute the published missed in DC using white needles even while single engine, and not do the special single engine missed procedure as published in aerodata. It took all 5 sim sessions in upgrade and constant prodding to get him to change his mind. I don't trust anyone anymore.
Not saying he's wrong, but just because someone is an LCA or sim instructor doesn't mean anything at this stage in our careers IMO.
By "Montreal Sim Instructor" I mean one of the Bombardier engineering test pilots that do sim work. Back in the day we used to wet lease the Montreal sims.
