pilot602
Also in a lot of airplanes (but not all), the RPM (with the last two zeros knocked off) should be higher than manifold pressure- i.e. 22/23 (22 in. MP/2300 RPM).
Not necessarily ...
It all comes down to the power chart. On our O-320's to get 65% power at any given altitude it generally requires that the MP is set higher than the RPMS (if you want to run with LOW rpm settings, which in many cases you do). So on a standard day at 7 or 8,000 feet we might set 2100 RPM and 22.8 or FT on the MP.
Higher MP actually helps seal the pistons thus increasing efficeincy. Low RPMs saves fuel and wear and tear on the engines. Using the low RPM high MP settings we routinely beat the book's fuel burn figures on 20-year old (actually 40-year old engines but they were overhauled 20 years ago), 1,000hr engines.
Not necessarily ...
