Why did the guy in the article get 709'd? Can the FAA 'just decide' to re-examine you? I imagine someone will have reported about the incident, unless the event was worthy of an NTSB report?
Alex.
Here is likely what caused a report to be necessary:
I hauled myself out and saw a PAPI light poking through the cloth underbelly, like a spear in a fish.
This one is a bit tricky but here is how to read it from NTSB 830 in the FARs:
830.5 Immediate notification.
(a) An aircraft accident or any of the following listed incidents occur:
What we care about here is the word accident, so lets find out what that means:
830.2 Definitions.
Aircraft accident means an occurrence associated with the operation of an aircraft which takes place between the time any person boards the aircraft with the intention of flight and all such persons have disembarked, and in which any person suffers death or serious injury, or in which the aircraft receives substantial damage.
A whole lot of hoopla right? But the key here is substantial damage, what does that mean? So lets find out:
830.2 Definitions.
Substantial Damage means damage or failure which adversely affects the structural strength, performance, or flight characteristics of the aircraft, and which would normally require major repair or replacement of the affected component. Engine failure or damage limited to an engine if only one engine fails or is damaged, bent fairings or cowling, dented skin, small punctured holes in the skin or fabric, ground damage or rotor or propeller blade, and damage to landing gear, wheels, tires, flaps, engine accessories, brakes, or wingtips are not considered "substantial damage" for the purpose of this part.
Note in here it mentions ground damage. I am unsure if this would qualify under ground damage, though I presume since it was just after a landing it would not. I believe by ground damage they refer to taxiing around and such.
There is one other section here that may have also required the report:
830.5 (a) (6) Damage to property, other than the aircraft, estimated to exceed 25,000 for repair (including materials and labor) or fair market value in the event of total loss, whichever is less.
I don't know what a PAPI system costs to replace but I would assume it isn't cheap. Either way, the substantial damage portion of NTSB 830 seems as though it would require a report. Just my opinion of course, but I know I would have reported it.
Tip to everyone: make sure you are familiar with this part and have your students become familiar with this section of the FARs. I have noticed many students don't even know it exists, it is an important section.
