You wouldn't consider an engine failure an emergency? I guess I should have worded it differently. How does power off gliding spiraling emergency descending manuever sound? I agree, it's definitely different than an emergency descent, where you can take it all the way up to the red arc and you're not gliding around a point.
Oh, I would most certainly consider it an emergency- didn't mean it to sound like I wouldn't. But I'm not going to be in any hurry to get down if I'm already over my landing point.
Way over Va in an emergency descent??? That depends on the CHOICE of descent method. Are you refering to the dive in the yellow arc hell er' high water??
Well, usually up to yellow line (140 kts. in the Seminole, 35-45 degree bank turns on the way down to clear the area), or higher. In any case, thats higher than Va.
My point was that these are two totally different maneuvers. The only similarity is that they're both used in emergency situations (albeit in totally different emergency situations). The steep spiral after maybe an engine failure and the emergency descent after a fire, or rapid decomp.
