pilot602
"Load factor" isn't the only thing that affects the stall speed.
[/ QUOTE ]It's not? I thought that level flight stall speed increased in a bank =because of= increased load factor.
But where's the lift vector pointing?
Why's it matter where it's pointing?? Like MikeD said all that matters is how close you are to CAOA. The lift vector could be pointing towards the earth (like it is during the inverted portion of a 1G roll), you still won't stall. Same idea; you can fly much lower than Vs and not stall, you just have to be doing a push over and flying at less than 1G.
It matters because now part of your lift is pulling the aircraft sideways instead of supporting its weight. To compensate for the partial "loss" in the vertical lift component your AOA must be increased. Thus more bank = higher stall "speed."
And I completely agree – and know – you can stall at any speed, bank and pitch but the conversation thus far has had folks saying the stall speed won't "increase" (more correctly stated the airspeed read off the ASI at the point the aircraft stalls) because they were flying at a "slow speed" which is not the case.
