SpiraMirabilis
Possible Subversive
I always liked the spin characteristics of the Tomahawk better than the cessnas.
sarcasm?
I must have missed the part in the c-172 POH where it says intentional spins are allowed. ...hummmm?
Well, I think I'll go and try it out anyways.
You may want to take a look at 2-7 of the POH.
Would you put a fat, fat, fat girl on the back of your scooter and expect it to handle well? Hey, some scooters just aren't built for fat chicks but in desperate measures sure...it will do! Com'on dude, your a CFI! Tell your student to rent ya'll a 152 or 150 to spin if he wants to see a spin. It will also teach him that it is A-ok to go out a spin any aircraft and the meanings in the books are just about next to nothing.
I know different models are different, but I'm looking at a 1977 172N POH and it says that spins are allowed. It says that all maneuvers that are required for the acquisition of "...certificates such as commercial pilot, instrument pilot and flight instructor..." are allowed. It says this under the Utility Category column. On the next page, it gives the recommended entry speed for maneuvers, and just reads that for spin you should enter it in a slow deceleration.
I know that spins are allowed in a 172, like you said, so long as you're within the Util Cat, but doesn't it say in the FARs somewhere that if you're with a student, legally, you can only intentionally spin the plane if the student is a CFI candidate and needs the spin endorsement?
FARs said:( d ) Paragraph ( c ) of this section does not apply to – (1) Flight tests for pilot certification or rating, or (2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by – (i) A certificated flight instructor; or (ii) An airline transport pilot instructing in accordance with 61.167 of this chapter.
Yea....about that....I think there is a choral reef in dire need of some more mass. Send all the Trauma-hawks there.
I would double check your W&B was utility and definatelly not forward or aft the CG limits. If so then I have no clue why the college took all the damn rear seats out and deemed them "spin cessnas."
Due to conservation of angular momentum as you recover when the aircraft pitches down the rate of rotation increases and this may 'spook' a student into believing that they entered an incorrect recovery when in fact it is to be expected.
