Some SAM questions (MH17 related)
killbilly
The other thread is...well...busy, and I've got some questions that folks 'round these parts might be able to answer. I know at least @Hacker15e and @MikeD (and I think @bunk22) have some first-hand training/experience in these matters...I know there's other MIL-aviation guys around here (@mhcasey, @frog_flyer and @Fencer) who can probably help answer, too. Yes, I'm leveraging the forum by pinging these guys.
1) Will accessing the debris field (I can't call it a crash site) tell people with specific expertise exactly what kind of missile hit the airplane? I suppose you might find explosive residue if you're sniffing for it, but I would also think that at the energies involved, the missile would simply be completely obliterated? Do they look for parts of the missile? Do these kinds of missiles actually impact the plane or just detonate a proximity fuse or something?
2) Do different SAM models have specific thermal blooms which are unique to their given model? Can you tell what type was launched by its IR signature? Would civilian radar coverage pick up a track on the launch? Is that the profile that would tell them what kind it was?
3) While commercial airliners don't carry threat receivers, there are a lot of other assets in the area (I am told) that do. Would another aircraft with a sensor pack (like an AWACS or other ELINT bird) "see" or "hear" the tracking/fire control radar of the SAM station? Or is the beam tightly directional and therefore not seen by a receiver it's not pointed at? (I know very little about fire control radars, obviously)
4) I read once that some AAA batteries are optically-guided to prevent radar jamming, flare decoys and also someone firing something like a HARM back down the beam at the launcher. Is the suspected battery that kind of platform? Could the crew have mis-identified the plane, thinking it was a Ukrainian Antonov or something? Just wondering about that.
I appreciate the answers/expertise you guys can bring to the table.
Sorry I'm not Hacker Mike or bunk.
Can't answer 1.
2. Don't know about specific thermal blooms Can a civilian radar pick up a track? Obviously not using secondary radar, but primary radar. It's a mountainous area, how good is the radar coverage. If a radar operator is able to pick up a primary radar paint on the SAM, it will obviously be a fast mover - you'll pick up the primary paint from the missile (if the radar is sensitive enough), the next time the search radar comes around, the second paint will be in another part of the radar screen, and it will depend on experience of the operator to tell that this new paint that is nowhere near the last paint on the SAM is the same track and that it is moving at Mach 3+. As most civilian ATC controllers are dealing with M.70-M.90 aircraft and are relying on SSR beacons associated with a primary paint, I doubt an ATC controller will notice just the primary radar track of a SAM if the ATC radar system hasn't filtered it out as a "spurious" track.
2 and 3 Can you tell what type it is? Can other assets see or hear the track/fire control?
A SAM system consists of two kinds of radar - a search radar and a track/fire control radar. an EW system will pick up both kinds of radar and each kind of radar has unique characteristics that you can tell which one it is. There are several ways a SAM system can engage. Before a SAM system can engage it has to know there is a target out there so that's what the search radar does. An EW receiver will see the search radar. From there it depends on how the SAM system is designed. Before it can shoot, a fire control computer has to determine a fire control solution. Normally the search radar usually does not have the precision required for the computer to determine a fire control solution from the search track. That precision has to come from a fire control radar. So a fire control radar is assigned to the target and "illuminates" / "lights up" the target. (Which by the way is considered a hostile act.) An EW receiver will see this immediately as a fire control radar has different radar characteristics from a search radar. For a pilot in a RWR equipped aircraft, this is his or her first indication he is being targeted.
Once a fire control radar acquires the target, the computer gathers the data needed to fire the missile, computes a solution, and it will either be engageable/"birds affirm" or not/"birds negat" due to whatever kinematics, etc. if it's engagable, then the SAM operator has some more decisions, how many missiles to send to ensure desired level of Pk, etc. and then order the missile engagement and send the missile(s) on it's way. If it's not engageable, you can still shoot, but the missile won't track the target as the fire control computer hasn't figured out the data needed to guide the missile, or if its due to kinematics, the target is outside the physical limits of the missile to ensure a successful kill.
I don't know the specifics of the Buk system, but wikipedia says that it is a Semi-Active Radar Homer. So that means to me that the target has to be continuously illuminated by a fire control radar during the entire time of flight of the missile. Think of the fire control radar/illuminator as a flashlight beam that you point at the target. The missile is looking for the reflected radar off the target. So the possibility of the missile being aimed at another aircraft and the missile tracking to the wrong aircraft is not valid one. The radar is not aboard the missile. So if the Buk is a SARH, the Malaysian aircraft was deliberately targeted. The missile is going where the fire control radar is pointed so the airliner was illuminated the entire time by the missile battery. Any time illumination is disrupted, the missile may track to the last known point, or it may self-destruct, it depends on how the system is designed.
I've worked with two different SAM systems (Mk-92 and AEGIS) The Mk-92 worked like above, AEGIS is different - the search radar has the precision to determine a fire control solution without illuminating the target, and I could do all the evaluation I needed without the illuminator giving any forewarning. Launch the missile, and about 2 seconds prior to impact, the fire control illuminator illuminates the target. So a pilot flying against my system has 2 seconds heads up and the missile is 2 seconds from impact when his RWR gear alerts him of a fire control lock or if I really didn't want to give any warning, I'd tell the system not to illuminate, and the missile will continue and intercept based on steering guidance commands from just the SPY-1 search radar. and all the pilot would sees is he was only on search radar the whole time.
4. optically guided AAA batteries - normally associated with gun systems, not really missile systems.
radar jamming - works for search radars, not so much for fire control radars, but then you can always burn thru jamming.
flare decoys - doesn't work against radar guided weapons
firing a HARM back at the launcher - not really used to defeat an ongoing SAM engagement as there isn't enough time - it won't take out the launcher unless the radar is on the launcher vehicle, but will take out the search or the tracking radar. but as far as defeating a SARH missile inflight - if you kill the illuminator before the SAM hits the target, fighter pilots do this though as the other fighter is usually the illuminator - I'm assuming flying relatively straight and level while the SARH AAM missile is inflight.
mistaken ID - personally I think this is what happened. ID'ing your target is part of the search phase and that is what consumes 99.95% of your time an a SAM operator, building a RAP (relevant air picture) and verifying the ID of your tracks and it's GIGO - garbage in garbage out. And whoever launched the missile against MH17, really didn't know who was on the receiving end.
So, caveat, about half of your questions have classified answers, so you're not likely to be satisfied with what you hear. Threat detection and defenses are always classified.
1) Yes. Personally, I think it's likely a Russian team would cover the field and find those bits and pieces and remove them, and I'd bet you $5 that one of the investigators on scene is a US-backed "asset". :tinfoil:
2) Civilian radar probably wouldn't pick it up- too small and too fast to make much sense (Mach 2-3+, not sure on exact speed of the SA-17 off the top of my head). Can't answer the other questions.
3) If you're in the area (and it's not likely you're flying within line-of-sight of a Ukrainian based SAM), *and* you happen to have the right equipment onboard, then you'd see the search radar. A tracking radar beam is generally much more focused, like a spotlight, and it's unlikely you'd detect the tracking sidelobes unless you're in just the right spot or have some seriously powerful equipment. It's not worth the money to install RWR systems on airliners, and would cause undue panic, because civilian airliners get locked up *all the time* on training routines.
4) There are optically guided missile systems, but those are intended for low/close-in threats, not airplanes at FL330. You'll need radar guidance to hit something up there. And yes, if you kill the radar on a semi-active homing system, you defeat the missile.
There are actually teams of experts who specialize in recognizing what kind of missile hit a plane by what's found in either wreckage, or what's found in damage of an aircraft that didn't crash. They look for all kinds of evidence to come up with what exactly hit the plane. The missiles involved could either hit the target, or prox fuse near it.
Likely not much detail could be derived from an ATC radar regarding a missile launch, except maybe some kind of skin paint, but nothing of any kind of detail of type, etc. Aircraft with missile defense systems have items onboard which can tell that a missile is approaching their aircraft, but not necessarily the type from any kind of IR plume only.
Probably one of the better aircraft to "see" or "hear" something electronically would've been an RC-135 aircraft, were one in the area. They have the equipment to detect and record the various signals that show what kinds of defense systems are where. Other aircraft with dedicated ECM packs would be next best such as a B-52/B-1, and lastly a common aircaft with some kind of RWR may pick up signals of search/track radars, but not record them....the crew would just have to have noticed them. For the area MH17 was in, none of the above aircraft were likely nearby.
4) I read once that some AAA batteries are optically-guided to prevent radar jamming, flare decoys and also someone firing something like a HARM back down the beam at the launcher. Is the suspected battery that kind of platform? Could the crew have mis-identified the plane, thinking it was a Ukrainian Antonov or something? Just wondering about that. .
Any AAA battery can be optically fired. But optical firing severely reduces the chance of a hit, the higher the altitude of the target. The bigger ones, 85mm/100mm, would create the "flak" type stuff you see in the WWII movies when bombers are overhead Germany. Meaning, it would have to be one hell of a lucky shot to fire at a jet at MH17s altitude, optically with no radar guidance, and hit the thing with one shot; without having the sky full of flak with multiple airbursts by multiple rounds.....which would be seen by ground video or even in the aircraft. It would be next to impossible.
Now, did you mean SAM platforms? Can they be optically fired? Some have the capability to be optically fired, then radar guided at a later time in the terminal flight time of the missile, thereby not setting off RWR systems in the targeted aircraft until such time that it's too late for the target to take reactive measures.
In any event, MH17 would've been mostly blind to a SAM fired at it: definitely electronically blind, and most likely visually blind. In the chance that the crew happened to see a missile coming up at them from their 9-11 o'clock, or their 1-3 o'clock.........much like a B-52 crew over Hanoi in the 1972 Linebacker II raids.......there wouldn't be anything they could do about it anyway in any kind of maneuvering sense.
That is such a terrifying image.
No doubt. Even the aforementioned B-52s from the Linebacker II raids, their crews described being able to see SAMs come up at them from launch.....if the SAM isn't moving with relative motion to you, then it's targeted at you. They also saw other B-52s getting hit/destroyed from SAMs coming up at them, as well as the heavy 85/100mm AAA airbursts and even had North Vietnamese MiG-21s flying formation with them prior to reaching the Hanoi area. All the while, the B-52s couldn't maneuver and were ordered not to maneuver in order to try to avoid or dodge SAMs (a legitimate order); they just had to watch their modern-day version of WWII Germany raids.
How far away can the search radar be? Is it mobile like the launcher? I guess the wreckage is 30 miles from Russia...
Yes, a search radar is fairly mobile, but takes time to set up as its a large array....it's essentially nothing more than a long-range ATC radar system, generally speaking; it just looks for aircraft / air targets; it's not a tracking radar for threat systems. It can be nearby the SAM system, or can be distant and just needs some kind of tie-in to the SAM to pass information on targets it picks up, to target aquisition radar systems.
In the SA-6/11/17 family, the search/track radar is attached to the launch vehicle. It is the thing sticking out on the left side of the photo. It does not need any outside radar system to find a target. The missile has a 20-ish mile range (Jane's numbers).
Usually in Integrated Air Defense Systems (IADS) like many countries have, there are a series of search radars (like, for example, the Spoon Rest) that can be located just about anywhere, and then the track information can be datalinked to the actual Transporter-Erector-Launcher. Once the TEL radar took over, it would be a self-contained search/track/missile guidance process on that track information
Highly unlikely that in an accident like this, the operators would be using some kind of datalinked operations where the search radar is handing off track data to the launcher. These systems all have sophistocated IFF/identification systems as part of the operation methodology, so if such remote/datalinked operations were being used, the operators at multiple sites would
Could they? Yes. The personnel and expertise exist. Can they? Perhaps. Access, tampering, contamination would be the primary factors in their success.
Yes, the excitation of any specific compound has a specific signature. But somebody would have to be watching the right place at the right time with the right equipment.
Maybe. Again with the right assets in the right place at the right time. Let's get the NSA on this; They apparently collect everything, all the time.
Is this even a question? Misidentified? Uh, YES. Doing things incorrectly is a particularly well developed skill in humans.
Why do you ask, btw?
With everything that has been going on over there recently I would guess several nations had assets in position to see something like that.
Because it seems to me that positive ID of the source is important, and I am curious about the tech and capabilities to do so.
As far as the question about optical-guidance/ID - I'm curious about the parameters involved if this is claimed as an accident.
Do you mean ID of the target?
Identification of your contacts consumes 99% of your time.
It's more a process of eliminating what it's not than saying what it is. And using educated guesses as to what it is. Not much is really available to ID things.
The only 100% means of positively ID'ing a contact is via visual means. Usually by having an air intercept controller directing any assigned aircraft to VID the contact.
Failing that, you're forced to rely on electronic means.
Transponder if associated with the contact. The only thing I get from that is your 4 digit squawk which means absolutely nothing as I don't have access to ATC data and can't associate a flight number with a squawk. If it's a military transponder I get more info from that.
Any electronic emissions coming from the contact. A civilian weather radar on an airliner is different from a air search radar from a military aircraft.
Where is it, what's it doing, how fast is it flying? High low? straight and level most of the time? On airway/off airway? Or maneuvering or loitering? What's its profile?
What is intel telling me what is potentially out there?
So that's the ID process. All of which takes time, which you might not have a lot of, so just like when flying airliners when you get rushed you make mistakes.
I apologize for my first post on this thread. I just threw everything out there as I didnt have a lot of time and I didn't know your base knowledge, so apologize if you already knew everything.
As the Russians haven't been very covert in any element of their movements or support of the separatists, there has been no great need to step up SIGINT. RC-135's often fly out of Incirlik but the actions of the Russians have been so brazen it has been easier to monitor social media.
This is exactly what our military shoot down teams do. For example we currently have elements deployed in Afghanistan who study not only crashes but also hits or reports of surface to air fire and analyze what it was/did. Its not just parts but impact patterns and recorded effects against like structural types. Every few years we take weapons and shoot them at old boneyard aircraft that way we can tell by what we see in a crash investigation if it correlates. They also look for parts and metals that shouldnt be present. The BUK family of systems (SA-11/17) and most SAMs outside of older systems use one of any variation of proximity fusing based on the type of warhead effect they work off of.
What we use in missile detection with our systems is classified. However yes there are systems that do exactly that, detect and classify a weapon based off of a few different parameters one of the primarys being the missiles launch signature. We do this because different weapons are spoofed by different methods so its important to go beyond the "Hey theres a big damn thing coming at us" level of indication in the cockpit.
3) While commercial airliners don't carry threat receivers, there are a lot of other assets in the area (I am told) that do. Would another aircraft with a sensor pack (like an AWACS or other ELINT bird) "see" or "hear" the tracking/fire control radar of the SAM station?)
I have no idea what we had in the vicinity to do its data collection. However having knowledge of some of our Signals Intelligence capability.... if we detected it with certain platforms we know exactly what it was and where it came from.
Almost all of the battlefield Radar Guided missiles produced out there are what is called a command guided system. A few systems are Semi-Active Radar Homing (Big example SA-6). Semi Active systems have the issue of requiring illumination of the target by a radar which the missile then sees, calculates intercept to and meets at a point in space. Command guided systems allow themselves to be guided "blind" being that they do not have the radar ranging so you are much less effective in reaching that meeting point in space with the missile. Its important to note a missile does not burn for a long duration of time (IE all the way to the target), they boost to an extreme velocity and use Kinetic energy to maneuver during the end game of their course. Without a good idea of what general vicinity to send the missile too though that Kinetic energy will be depleted long before the missile can correctly maneuver to target. I highly doubt they were worried about an Anti Radiation attack where they would keep their radars off, more than likely they were using radars for intermittent periods so as to deny Ukrainians with a constantly updated threat picture and "spring the trap" so to speak. If this was the case than the likelihood of them spending large amounts of times thoroughly ID'ing a target is probably a lot less.
Funny thing is......systems like the SA-11/12/15/17, etc, would look at your (and my) helicopter and think "...not even remotely worth my time or effort".....
....just as the ZSU or 2S6 parked along with him engages us. :)
Gauntlet keeps me awake at night.
At least a weapon system has the right opinion on helicopters.
:biggrin:
