beasly
Hi all, wondering if you can verify some stuff for me that I am seeing/hearing on the jets coming into ORL--I am about 950 hours mostly prop time about 10 in a C-340A turbocharged and the gratuitous 2+ in the ATP Cessna jet (Which I thoroughly enjoyed--thanks ATP!). I.e. I am NOT a jet driver.
The gist of my question(s) is(are) do the normal stuff we do in small singles/twins translate directly to jets? I.E. is a jet more/less forgiving than a small plane in the approach phase.
Flight regime, case 1. Lose power, increase angle of attack to bleed airspeed quickly while maintaining altitude.
Yesterday on my walk, going by the ORL VFR, this Continental jet is coming in from the east making a left turn to intercept 18R at ORL and he has a "very" high angle of attack coming in (guess-timating between 10 and 20 degrees--enought to make beasly say, "Holy crap! that's a high angle of attack!") during the turn. Me, I am guessing he needs to bleed some airspeed. After the turn, you could see him slowly lower the nose, hear some power being added briefly and see it transition to a normal flight attitude followed by power being reduced. Also, in a small cessna or piper, this is perfectly safe, but your window for error is much less--so you gotta be on your toes--high angle of attack, turn, clean.
True in a jet?
Flight regime case 2. "Large power changes" during approach/intercepting glide path.
In small props, I teach this. the theory being to "minimize transition times and return to steady state flight". Take the simplest case of change in airspeed while maintaining straight and level; for a speed increase, increase power well beyond your target speed's power setting, let the a.c. transition quickly to the new airspeed and then reduce power to your new higher airspeed's power setting. Conversely, to lose airspeed, reduce power well below your target airspeed's power setting, let the airspeed bleed of quickly, overpower to stabilize at the new lower airspeed and then reduce to cruise.
I hear this especially with the bigger jets coming in--I would like to verify that it is not that effect that you get (I forget the name) when you hear a car stereo passing by at 50 and the pitch drops as it passes.
Also, you guys seem (if I am hearing correctly) move the throttle levers more quickly than we do on the pistons. (fwiw, a flight school I worked at had a "famous" 152 where the recovery from a stall went....reduce angle of attack, full throttle, pray the engine revs within 10 seconds...)
Flight regime, case 3: having fun.
I tend to see this with the smaller jets coming in. The big boys UPS, Fed-Ex , Virgin come in well established. The smaller jets (Southwest seems to do this the most) will come in off and easterly or westerly approach to final, and then wait till the last moment and then really bank it over. Beasly is like, "dang! I am jealous".
Does this happen?
Thanks for your help.
Cordially,
b.
True in a jet?
Does this happen?
Cordially,
b.
