So whats going on in Florida?
DPApilot
GUYSH! GUYSH! GUYSH!
CTY UUA /OV CTY/TM 2017/FL150/TP SF 34/IC SEV ICING/RM ARCFT LOST CONTROL AT 150. DESC TO 090 REGAINED CONTROL. CWSU ZJX
Severe icing in Florida? Uhhhh.... I haven't looked at the weather in a few days but 15,000 in FL isn't exactly a ice prone place. Perhaps this was someone's first encounter with icing and got spooked while riding through some bad bumps?
Likely not being that they were flying a Saab.
I've been is some pretty bad ice in FL... It's cold at that altitude, and there's often lots of moisture in FL. Heck, Comair almost lost a Brasilia to icing near south FL back 10 or so years ago.
Fair enough... I've never had any issues but as you said there is a lot of water moisture.
Standard lapse rate of 3 degrees/1000 feet. Figure it's 75 on the surface, at 15,000 it could be right at 30 degrees.
BLAMO! Ice.
That, combined with the low pressure system that was over the panhandle yesterday. Bad combination.
Not saying this is the case, but read the freaking weather packet with the release. There is good information in there and it might just save your ass one day.
The first icing I ever encountered was in florida. Lots of moisture, add in a front and blammo.. you've got more than you can shed.
Worst I've encountered was Seattle to Wenatchee...warm/moist air off the sound, hits the cascades and gets pushed up/cooled rapidly as you're flying at 15,000ft across...BAM! and bob's your dads brother... The Q400 grew horns off the ice probe on the windshield whipper.
